AH FabricationsChris Nott
Results 1 to 7 of 7
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Turbo oil return pipe
    Fitting my turbo and need a gasket for the oil return pipe on the bottom of the turbo. Was wondering does it need to be anything special like a metal gasket or can I just use gasket paper or will it get too hot? If it needs to be metal, where do I get one from?
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    TPS should do it? I got my pipe changed last year and on the recipes I'm sure it said gasket. Not at home so can't really check the codes
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,567
    OEM metal gaskets all day long... dealer or TPS as a supplier... paper gaskets typically get supplied with the hybrids I have been involved in fitting and I never use um... I use OEM ones on my GT30... never leaked
    <tuffty/>
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,362
    oem all the way, TPS or Audi, but you're too late today as they're both shut now.
    Should have bought everything before you started :P
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    I forgot the return pipe needed a gasket
    Spent nearly £47 at Audi yesterday just getting a thermostat, turbo/man gasket, turbo/dp gasket and inlet man gasket. Was a bit shocked at the price, but I saved 6p as I didn't have enough on me n they let me off.
    PS3: Broady_11
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,362
    it's OK, I forgot that very same gasket myself last time I did a swap!
    realised I'd forgotten it, and was very careful when removing the old one, and I've re-used it no trouble. few thousand miles later and there are no leaks, so happy days
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    I wanted to do the same but I can't find it, I thought I did and went to fit it then realised the bolt holes were too close, god knows what that gasket is for.
    PS3: Broady_11
  1. Turbo oil pipe
    By HOTTIGGER in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th May 2012, 18:42
  2. A4 1.8T turbocharger oil return pipe
    By nik.gibson in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th March 2011, 19:51
  3. Replace pick up pipe naturally, also clean oil feed / return pipe?
    By mikem1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th March 2011, 18:05
  4. leak on oil return pipe to sump
    By barters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2011, 19:35
  5. Turbo Oil Lines
    By BarryT in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th October 2003, 22:29
