AH FabricationsEM Tuning
    Danman1's Avatar
    Thorough noob
    Sep 2011
    West Midlands
    338
    Engine management light is on...
    Right, so my engine management light is on, but it wasn't on before I did two things today.
    1. I have installed the Tups LED light package for the whole car including number plate lights (looks amazing btw), while doing this one of the fuses for the interior lights blew and I had to replace it. All is fine now with all the lights working etc.
    2. Accidentally started the engine with the MAF unplugged. Didn't drive it anywhere, I just started it then turned it off once I realised after about 3 minutes.
    Apart from these nothing new has happened to the car. Can I do a sort of reset to turn it off or will I need to turn it off via VCDS?
    Dan
    Essflee's Avatar
    Mar 2008
    2,007
    The cars just thrown a code because you started it without the maf being plugged in, I did the same thing recently when I fitted my tip, the code just needs to be cleared with vag com or a similar code reader .
    revo'd
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,062
    Having the MAF disconnected doesnt normally keep the EML on, you normally get the traction control light on, but once connected and car off and back on clears that and the TC light will go off, I have done this a few times to check the maf and never had the EML come on.
    Also the LEDs wont have any effect on the EML either, so could be coincidence.
    Have you been out for a drive, does it feel any different?
    Also, do you have or can you get access to VAGCOM to get the car scanned at all?
    Danman1's Avatar
    Thorough noob
    Sep 2011
    West Midlands
    338
    Quote Originally Posted by Nilz View Post
    My TC light did come on yeah but went off after a bit, took the car out for a spin thinking it would sort itself out but it hasnt, the EML is still on.
    Im meeting Chris (rhubarb4) on Tuesday night for him to have a scan and hopefully clear the issue! If not ill be posting another thread with all my problems
    Dan
    Nilz's Avatar
    Apr 2006
    10,062
    No worries dude, you have my number, so give us a shout if you need a hand at all next week.
    Let us know how you get on.
    Aug 2010
    1,540
    the eml will stay on as the engine ecu needs the signal from the airmass to calculate engine load. you'll have a sporadic code in there for it being unplugged (open circuit).
    unlike the traction light (which also needs the engine load signal) which will go out once the airmass is plugged back in, and engine turned off and back on.
    just get it reset.
  1. Engine management light on dash
    By imported_ashs3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th May 2005, 17:55
  2. Engine Management Light on all Week now off again
    By MingBluS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th May 2005, 21:54
  3. Help Engine Management Light On
    By taj in forum TT/TT-S/TT-RS Forum
    Last Post: 13th January 2005, 20:07
  4. Engine Management Light
    By Tendaimwari in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2004, 21:11
  5. Engine Management Light
    By StephenBogan in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th September 2004, 13:06
