AH FabricationsVolks Autos
Page 8 of 8 FirstFirst 12345678
Results 281 to 299 of 299
Like Tree6Likes
Thread: Bumble is poorly....
  1. #281
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Going back to the discussion about the flywheel chatter, it may now be as bad as all that to be fair.
    As some of you know I have been running with no lambda connected for the last 6 months as the injector scaling has been out of whack. The map was for 550s and I was running 630s. Unisettings was set to pull 20% of fuelling out to compensate. This meant that with the lambda connected, it would just adjust the trims and screw the fuelling up.
    I've been away for the last week and whilst I was Bill scaled the injectors on the map for me properly. This means that I now and back using lambda control.
    One of the side effects of running with no lambda and different injectors is that the fuelling on idle was rich, meaning it was also unstable - very jumpy.
    I think it was this idle instability that was causing that chatter. As soon as I plugged the new lambda in to test after fitting, the chatter was almost instantly gone.
    I think Bill has also tweaked the idle up slightly on the map, and this combined with lambda control has practically cured the chatter altogether....
    Maybe it's not as bad as all that after all....
    Homer Simpson
  3. #282
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,235
    Very good to hear mate. So now the chatter has gone would you recommened the smf or not?
  4. #283
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Still not sure. There are things about it that make me suggest not. The negatives seem to outweigh the positives.
    It revs up REALLY fast. Touch the throttle in neutral and you're at 3K before you know. Makes driving a bit tricky as rev matching is hard.
    Also, hill starts are now a real ballache as she does really want to stall.
    Hill climbing is far better with the SMF.
    Homer Simpson
  5. #284
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,382
    You're my favourite Pikey mechanic!
  6. #285
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    It worked....
    Homer Simpson
  7. #286
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,382
    It worked....
    That's why you're my favourite
  8. #287
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Pushing the boundaries of bodge.
    Homer Simpson
  9. #288
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,789
    Quote Originally Posted by Sam_ View Post
    I wonder what causes the chatter? Imbalance? It's only something I've heard about with 1.8Ts. Can you get round it by adjusting the idle compensation in vcds?
    So raising the idle huh
    I wanted to raise mine slightly as the VF dogbone can be quite bad without the AC on but haven't got around to doing it yet.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
  10. #289
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    You can raise idle with UniSettings... I upped mine in the map to 880rpm as this is where I had it set in unisettings before...
    <tuffty/>
  11. #290
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,789
    Is Unisettings cool with any remap? (I'm unsure what map I have)
  12. #291
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    To be honest dude, it was better at previous idle - it was the fuelling being too rich at idle that caused the jerking of the engine, and consequently the gearbox.
    Idle being upped has improved it further , but the fuelling was the main issue there.
    And yes, Unisettings should be map independent.
    Homer Simpson
  13. #292
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Homer Simpson
  14. #293
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    MY SMF doesn't chatter much
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  15. #294
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,382
    because yours still weighs too much
  16. #295
    Westy's Avatar
    Dec 2008
    17,283
    That's the beauty of it. None of the DMF issues but none of the SMF issues
    S3 Build Thread
  17. #296
    beachbuggy's Avatar
    Surrey
    1,746
    How do the 630's run? Read that there not that good, I've got 630's on the new build but now worried they might not be that good, 550's where awesome so just a little anxious about fitting these
  18. #297
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    I run 630's and they are ok... the reports I have read about suggest that idle is an issue but idle on mine seems fine... you need to dial TVUB in of course...
    I did consider using 550cc Bosch with a 4bar FPR as I have an inline pump and the Bosch injectors are allegedly 'better' atomisation etc... they also do a 750cc version of the Bosch but... the set I have seen (used on the 2ltr stroker LCR Bill had in recently) had 750cc scratched into them and the same part number as the 550's so not sure what tomfoolery has gone on to make them flow more and I haven't found any info out to back up the claims or what differences made to TVUB values that are already fairly well documented..
    The one claim I have seen of the 630's fouling over time is cobblers IMO... mine are clean as a whistle and have been in since I first did my BT conversion... I think thats more subject to PVC deletes and stuff and the context can be difficult to follow on Nef as they often refer to 30v tuning rather than 20v tuning... no idea how much of the PCV etc is traditionally removed on those builds..
    <tuffty/>
  19. #298
    RIP S3dave
    May 2004
    nr Glos
    7,195
    idle bumped 60rpm i think from memory wellyboots
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
  20. #299
    Westy's Avatar
    Dec 2008
    17,283
    Has going back to lambda and proper fuel mapping made any difference to power?
    S3 Build Thread
  1. Poor Joke of the Day
    By porker968 in forum General Chat
    Last Post: 23rd September 2004, 15:52
  2. How poor is the symphony II headunit?
    By imported_MattT in forum In-Car Entertainment
    Last Post: 7th September 2004, 12:03
  3. Poor chippin job
    By mastertech in forum Tuning
    Last Post: 8th May 2004, 17:24
  4. Poor Performance
    By MingBluS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th January 2004, 22:12
  5. My poorly S4 (Thanks to Dundee Audi)
    By DavidR in forum Tuning
    Last Post: 12th October 2003, 17:23
