Badger5AH Fabrications
Results 1 to 8 of 8
    northcountryboy's Avatar
    Sep 2005
    Inverness
    25
    RS4 reps arch fouling on S3- spacers ?
    Hi,
    the S3 failed it's MOT today,
    they said my 18" RS4 reps were rubbing on the inside
    of the front arches on full lock.
    I did think that they sat further into the arches than the
    17" Avus rims.
    Has anyone else had this problem?
    Don't know what the offset of the 18"s are, would need to take one off &
    see if it's stamped in the back of it.
    Would fitting spacers cure my inner arch fouling ?
    I'm going to book it in soon to get the suspension done,
    so I could get them to fit spacers at the same time.
    Thanks,
    Scott.
    Oct 2005
    wirral
    45
    Re: RS4 reps arch fouling on S3- spacers ?
    not sure but on the genuine wheels the offset is behind the center cap.
    would make it a very quick job to check if its the same on reps [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Sep 2005
    Inverness
    25
    offset was stamped on back of spoke, ET42 !!
    the wheels are multi fit for 112mm and 100mm , looks like they've gave me an a4/s4 offset.
    back to the shop tomorrow,
    starting to get a bit fed up now !!
    imported_VaulterTim
    Scott,
    ET42 is a massive offset. I think RS4's have something like that as standard because they have wide arches. So yeah, get yourself back to the shop and have a word [img]/ubbthreads/images/graemlins/wink.gif[/img]
    Looks like they gave you the wrong ones. (And as a result your car has failed it's MOT... Grrr!)
    You'll need something in the region of 30 to 35 for an A3/S3...
    Tim
    PaulRS3's Avatar
    UK
    1,006
    OEM 18" on my S3 is ET33.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,511
    [ QUOTE ]
    [/ QUOTE ]
    ET42 actually pushes the wheels into the arch, as it's actually ET-42, Genuine OE RS4 wheels have an offset of ET20 to push them out and fill the wider arches. [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    imported_VaulterTim
    My bad... you are of course correct [img]/ubbthreads/images/graemlins/bang.gif[/img] Apologies [img]/ubbthreads/images/graemlins/blush2.gif[/img]
    I sat for a while before posting that and wondered what I had said wrong (because he originally said the wheels were fouling on the INSIDE edge...)but, since I'm a woman, I can never be wrong so apology rescinded [img]/ubbthreads/images/graemlins/grin.gif[/img]
    Sep 2005
    Inverness
    25
    have been back to shop & they're
    sorting me out with some spacers.
    have got the avus 17's back on for the re-test
