Badger5Monster Motorsport
View Poll Results: Which one???
Voters
25. You may not vote on this poll
  • Better
    19 76.00%
  • Worse
    1 4.00%
  • No real difference or improvement
    5 20.00%
Results 1 to 23 of 23
    AL_B's Avatar
    Warrington, Northwest England
    1,564
    Front Aero Wipers - Better or Worse than standard wipers?
    Been thinking about this mod for a while, as my passenger side standard wiper never clears the screen properly, and the drivers side squeaks at high speed.
    So for those who have performed the Aero wipers mod, what do you think, better or worse than standard?
    Drill's Avatar
    Land of Good Beer, and better Roads :-p
    928
    Re: Front Aero Wipers - Better or Worse than standard wipers?
    Al, if the cost doesn't hurt, I'd say do it [img]/ubbthreads/images/graemlins/crazy.gif[/img] I tested my Aero-Wipers by hitting the washer @ 200kph and while they missed about 1/2 an inch on the end, they still cleared the screen, whereas the std wipers would lift completely off by 160kph [img]/ubbthreads/images/graemlins/frown.gif[/img] The only thing I'd add is that replacements are a bit dearer. Over here it's about 40 for a new set of fronts, and (IIRC) about 15 for a new Touran blade on the rear.
    HTH [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    imported_gek
    [ QUOTE ]
    whats IIRC mean? areowipers are better btw , any1 know where best place to get the replacement blades?
    [/ QUOTE ]
    If I Remember Correctly
    Oct 2005
    wirral
    45
    bosh make them for audi [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Drill's Avatar
    928
    Yeah, and then charge LESS than Audi [img]/ubbthreads/images/graemlins/angel.gif[/img]
    amb276s3's Avatar
    bird spotter
    Sep 2004
    Lincoln UK
    292
    I was getting an annoying wind noise from the windscreen area, changed to aero wipers and all is quiet, plus they do stay on the screen at higher speeds.
    AL_B's Avatar
    1,564
    Thanks everyone, that's great feedback.
    AL
    necroeire's Avatar
    Feb 2004
    Ireland
    1,003
    I ordered my Aero wipers this week from VAG-Parts. I will do a before and after comparison with pictures when I get them.
    Where do you guys buy your replacement blades? And how much?
    Drill's Avatar
    928
    Haven't had that problem myself, although out of habit, I tend to change mine every 4 months or so [img]/ubbthreads/images/graemlins/crazy.gif[/img]
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,569
    I love the aero wipers in terms of functionality and looks as they sit flatter on the screen
    Drill's Avatar
    928
    I've had mine on for prolly 2 years and haven't noticed any accelerated wear at all [img]/ubbthreads/images/graemlins/crazy.gif[/img]
    Nov 2004
    St. Albans
    61
    next question (albeit for an A4). Got the aerowipers through the post. Does anyone have any instructions to replace the old wipers?
    Drill's Avatar
    928
    No instructions, but I took pics while changing mine. <font color="red">Here</font> and on the next page [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Hope it helps [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Nov 2004
    St. Albans
    61
    feck. Managed to remove the nut, but the arm is not coming off. I've tried wiggling it while trying my best to maintain upwards pressure, but the whole spindle just rocks backwards and forwards a few mm with the arm. Any ideas?
    Sep 2004
    Glasgow
    919
    wd40?
    concoursneil's Avatar
    Aug 2003
    Plymouth UK
    327
    Do they do wipers to fit both passenger and drivers side?
    Also do you have to replace the arms if so what are part numbers for arms
    Nov 2004
    St. Albans
    61
    tried a squirt of WD40. No joy.
    Drill's Avatar
    928
    [ QUOTE ]
    [/ QUOTE ]
    Yeah, I think my pics only show the drivers side cause I wanted to test them out before swapping both [img]/ubbthreads/images/graemlins/crazy.gif[/img]
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,511
    I used a spanner to lever the old wipers off, as they were literally welded on! Place one end on the end of the spindle and the other under the edge of the old wipers and yank away, make sure the wipers are lifted off the screen of course [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    The Slug's Avatar
    Nov 2004
    UK
    1,853
    fitting is easy, heres what u do step by step:
    Fronts,
    Lift bonnet, remove black caps that cover the nuts, use spanner and slaken do not fully remove, do this for the two nuts, drop bonnet down (do not fully close it) then put ignition on put wiper on and when they reach vertical point stop them by turning ignition off.
    Once wipers are in upright position, pull the wipers back (ie like ya gonna wash ya car, lol) then gently riggle the wiper from off the nut, reapeat same for other front wiper.
    Mine came off a bit easy or easier for the fact that its a 2003 model so the wipers arent rusted/bonded to the bolt, if u know what i mean, word off warning tho, just be careful when wiggle the wiper arm off because u end up very close to the windscreen, so just be careful.
    U still with me, lol.
    Next up, wipers are now off, put ignition back on make sure the wiper position is back to normal,
    keep your eye on the motor bit so's u know u have it in the right place.
    Get the Aero wiper arms with blades already fixed to them, check that the blades are on the correct arms, think mine were bigger blade on the drivers side etc..
    Riggle new arms onto bolts and get the angle lined up to where the old blades used to sit, put nuts on (use original ones u took off) u will need to lift bonnet once wipers are in place to tighten up nuts with ya spanner, don't over tighten just nip it then nip it again should be fine.
    Then check to make sure wipers and washers work as normal.
    Rear,
    Pull off cap that cover the washer jet thingy, remove nut (in the aero kit u get a black nut, use this new nut instead off the original) same thing riggle off arm, dont have to centre arm or anything, once removed, position new arm/blade in the same position as old one nice and level, then put new black nut on and clip the jet cover over , JD job done, check the blade and washers work fine!!
    Hope this helps matey!! If u need pics, i will takes some for u.
    Rich
    imported_CurryMilkShake
    Longevity..
    The set of aeros that were on my car from new, I replaced at about 20,000 miles. I've done another 8000 or so on the new set and notice no deterioration at all yet..
    Quite happy with that as a replacement interval, and to be fair they were only just starting to deteriorate at 20k.. perhaps I'm just fussy!
    The only advice I have with Aeros - dont use RainEx!! Mine really really didnt like it, and went from perfectly smooth to judder judder judder..
    necroeire's Avatar
    Feb 2004
    Ireland
    1,003
    Nice one Rich, I'll be changing my wipers during the week so cheers for the instructions.
    I'll do some pics and will post them too.
    The Slug's Avatar
    Nov 2004
    UK
    1,853
    [ QUOTE ]
    [/ QUOTE ]
    No probs mate
