AH FabricationsJMB Retrofits
    Feb 2011
    Somerset
    241
    Boost pressure AUM?
    Can anyone please tell me the boost pressure max and holding on a standard AUM, in psi, Thanks?
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,377
    6-7psi matey, peak and hold. stage 1 map will see you spike 18 or so, which will taper off to 10-12 at the redline. Stage 2 map will see you spike 21-22 and hold it for about 500rpm before dropping to 12-13 at the redline.
    Feb 2011
    Somerset
    241
    Thank you.
  1. Boost Pressure A3 aum 1.8T
    By DenCar in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th August 2010, 09:09
  2. Turbo boost pressure?
    By speedyp in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th January 2009, 21:54
  3. Boost pressure?
    By Defratos in forum VCDS (formerly VAG-COM) forum
    Last Post: 13th April 2007, 02:48
  4. Manifold Boost Pressure Switch
    By mtsakmakis in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th December 2004, 20:30
  5. Boost pressure control valve
    By imported_SYNAPS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2004, 09:33
