Monster MotorsportChris Nott
Results 1 to 30 of 30
    Oke Phill's Avatar
    Mar 2012
    147
    Rear tie arm snapped?
    Hi everyone, i had a knocking noise coming from the rear of my car, and i found this.
    I have had a good search but i still have some questions that im unsure on. So far i have found out this could have been caused by a seized bearing at the end of the arm?
    1st is the end of the arm that has snapped, is that the bearing?
    2nd if so how do i get it out
    3rd what is the actuall name of the rod that has snapped?
    Any help would be great thanks.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Typical rose joint failure, is your car a preface lift?
    Its called a tie bar,
    The bearing is pressed in the hub...
    Oke Phill's Avatar
    Mar 2012
    147
    Thanks dave. My s3 is a 2000 plate im not sure if that is the face lift or not? Ill have to whip the hub off and get a new bearing and get it fitted by a garage. I have found a new arm already. All good fun a? lol.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    There was an early recall on the rose joint thats all, unsure if it still stands after 12 years though.... probably not...
    boost-addict's Avatar
    Aug 2011
    977
    nasty ill be checking mine tomorrow, do they just fail or do you get cracking/signs of wear
    Oke Phill's Avatar
    Mar 2012
    147
    Ah i see, yeah no worries. Ill try get both sides sorted just to be sure. Thanks Mate.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,559
    Should see hairline cracks if its about to go but most people only notice after they break... worth checking tbh as this seems to be getting more common
    <tuffty/>
    Oke Phill's Avatar
    Mar 2012
    147
    Quote Originally Posted by boost-addict View Post
    I was reading in another thread to listen for creaking, but i did not hear this, and i just had a rattle but that was when it snapped. gotta be worth a check tho bud.
    tonks s3's Avatar
    May 2012
    33
    One of mine snapped the other week! Would suggest to have a look around the fork in the bar for cracks/stress, I replaced both sides due to corrosion
    Hope this helps :-)
    Aug 2011
    977
    mmmm, i get creaking almost like a craking parcel shelf. so defo going to look. wouldnt want that happening in a corner or motorway thats for sure.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    On a side note, what break setup you running? They look awesome.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,511
    Time to custom make some some fixed length stainless steel tie arms to match the adjustable ones Dave!
    Oke Phill's Avatar
    Mar 2012
    147
    Quote Originally Posted by tonks s3 View Post
    Hope this helps :-)
    Did you replace the bearing as well?
    Oke Phill's Avatar
    Mar 2012
    147
    Porsche 4 pot rears, they are massive. Ill get a better pic up once i get home. The disks need a skim tho, just where it has been parked up.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    What you done to retain the handbrake mate?
    SEAT owner
    Mar 2012
    Worcester
    77
    Also interested in these rear brakes
    When i broke my S3 awhile ago i assume at the end of the tie arms it was just a bush, no bearing
    I can also see how easily they can break as they arent very thick material
    Apr 2012
    N. Wales, LL22
    1,224
    does anyone slacken these of then tighten when on the ground when lowering?
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    Oke Phill's Avatar
    Mar 2012
    147
    Ill get you a pic of the hand brake, it has a extra bit on the bottom of them for it. autho it is ****e.lol. Ill post a pic up when i get back home tonight.
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,361
    Look closely Danny, you can see a second handbrake caliper below the porsche caliper in the first pic
    Oke Phill's Avatar
    Mar 2012
    147
    Quote Originally Posted by Ronin225 View Post
    I thought it was strange as well, i thought it would be a bush and not a bearing. Ill find out for sure when i get it sorted on monday. They are not very thick at all, i was thinking of making up a re enforced set, may be as i am slightly nervous of this happening again.
    Oke Phill's Avatar
    Mar 2012
    147
    Well spotted Mr Prawn.
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    I had a KW adjustable tie bar snap 2 years ago now - snapped straight through the threaded bar that provided the adjustment - something like 1/2inch solid steel!
    It's the terrible state of our roads combined with the age of our cars means more and more failures like this.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    Oke Phill's Avatar
    Mar 2012
    147
    Bit of a resualt, stripped this down today and the rose joint was siezed solid. But with a wire brush, wd40,grease,a bar and a big hammer i have sorted it out and it runs free again. Just going to go through the other joints tomos.
    Any way here is a pic of the rear breaks i said i would put up, im thinking of getting the disks skimmed as they seem to have some rusty pits on the rear. Im gonna re furb the paint on them as well, just waiting for some stickers.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,783
    Gotta be pointless them being so big but awesome none the less!
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
    Oke Phill's Avatar
    Mar 2012
    147
    Quote Originally Posted by Sam_ View Post
    I have thought that, still love em. random note I was supprised with how light the caliper was when i removed it, i recon they weigh less than my 106 dervs calipers which are tiny.lol.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    What stup you got up front mate? You fit it all yourself mate?
  28. #27
    Oke Phill's Avatar
    Mar 2012
    147
    Heres a pic of the front set up mate. When looking for this car/next project i tried to get a s3 with as much done as i could find to keep costs down in the long run (yeah right!) so i cant take any credit for gitting thr brakes as they were already there. they must of cost someone a pretty penny tho.
  29. #28
    May 2011
    Surrey
    Quote Originally Posted by Oke Phill View Post
    From the person who bought them and fitted them on the car at qst I can tell you they cost a fortune lol. Handbrake always fails mot but just neededs tightening every time, 5 min job. Qst stopped making the rear kits after a few months due to the handbrake calip being useless so it's a pretty rare conversion, just ask kim
    2005 A3 8P 3.2 V6 - The run around
    2012 - Range rover Evoque - the Misses car
    2010 - Aston Martin DBS Volante - The Weekender
  30. #29
    Oke Phill's Avatar
    Mar 2012
    147
    Lol! yeah the hand brake is a bit poo, im gonna get out and try and sort it this weekend, any tips would be nice Andy.
  31. #30
    May 2011
    Surrey
    Always leave it in gear when you park . Seriously a pair of players always works, it's pretty straight forward bud
  1. Stainless Steel Adjustable Rear Tie Arms Update
    By s3dave in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th February 2012, 13:33
  2. Rear Tie Arm Replacement-too adjustable camber arms "How To"
    Last Post: 13th December 2011, 14:31
  3. std S3 rear tie arms wanted
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th September 2010, 19:40
  4. Rear tie arms/Camber Adjustment Product
    By Dave_Bayern in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 7th August 2007, 15:24
  5. adjusting rear tie arms?
    By Banwell in forum Handling
    Last Post: 3rd April 2004, 10:24
