EM TuningMonster Motorsport
Results 1 to 7 of 7
    Erf
    Oct 2006
    Kingston
    234
    Pre vs Post facelift S3 rear diff
    Hi guys,
    Does anyone know if I can replace my post facelift rear diff with a pre face lift rear diff that has ESP? I know most pre facelift S3's don't have ESP, but I've found one that does so I'm assuming (and hoping) that they will be compatible. Any ideas?
    Silver 2002 S3 - Alloy Mirrors - RNS-E - Parrot MKI9200 - Beesting Ariel - Stealth Catch Can - S2000 Air Filter - R32 Rear ARB
    Oyster Grey 2008 A6 Avant S-Line 2.0TDI DPF
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    I think they should be, i believe its the haldex system thats the difference but not 100% sure
    Erf
    Oct 2006
    Kingston
    234
    to be fair it's the haldex system I'm most interested in! My haldex mechanism has gone kaput and Dean from 4rings has advised me that I need the Haldex clutch replaced. I thought the easiest way to do this would be to buy a whole rear diff with the haldex unit attached and then just bolt on the new unit and connect it to my haldex ecu...
    Found a pre facelift one that had ESP and wondering if that would be fine.
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    Yeah should be fine.. The only thing I'm thinking is pre facelift don't have an earth strap, but you can just makeshift one! The haldex should work fine to my knowledge!
    Erf
    Oct 2006
    Kingston
    234
    Hi Guys,
    Just to give you an update on this. Audi have confirmed the part number from the donor car and my car are the same so I have gone ahead and purchased the rear diff. However, I'm concerned about the earth strap. Is this going to mess things up for me? Can I retro fit an earth strap to a pre facelift diff? Has anyone done it before?
    The diff is with my mechanic and he is due to fit it on Monday. Does anyone have a pic showing how the earth should be connected to the rear diff on a post facelift car?!
    Any help woould be appreciated!!
    Already spent a shed lost in the last month (new front ARB, new R32 rear ARB, new front wishbones, replaced the steering rack) so I don't want to waste money cocking this up!
    EDIT - found this earth strap @ halfords Halfords | Halfords Braided Earth Battery Cable 22cm (9")
    Erf
    Oct 2006
    Kingston
    234
    Actually, I've found some good pic here - Replacing haldex earth question!?!?.
    But if someone can let me know if I can retro fit this to an old rear diff? Do I even need to?
    AARON77's Avatar
    Nov 2007
    kingston sw london
    1,314
    I replaced my diff with the facelift diff & had no issues at all
    the plugs were completely different but we spliced them together with no problems too
    Comrades of Vag find us on Facebook
    https://www.facebook.com/comradesof.vag?ref=hl
  1. S3 pre- and post-facelift diffusors interchangeable?
    By Qua3ttro in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd May 2012, 11:51
  2. xenon headlight wash pre to post facelift
    By rickyquicky in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd November 2010, 21:33
  3. Pre to post facelift headlight upgrade
    By calvin in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th February 2010, 12:43
  4. Pre or post facelift A4 B5 avant?
    By sidkiz in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th December 2009, 13:40
  5. S3 paint colours pre and post facelifts
    By wagon in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd October 2009, 11:19
