Turbo upgrade ??
I've been looking into the turbo upgrade side as well. the TD04 i sthe turbo found on some scoobies i.e the RB5, this turbo spools up quickley but you prob won't see any significant gain (if any) at the top end. Power band is prob similar to what the S3 has just now except with a slightly quicker spool up.
The manifold might not have a significant nicol content as apparently this is an issue with us supplied manifolds??
I'm not sure if this turbo would work with the standard downpipe as I'm not sure what the flanfe fitment is on the OE one.
Some of the issues that have also been mentioned before is the positioning of engine bay slightly differs.
There are ppl on here who seem to be very clued up on this side, Rich, Ryan and a few more who I can't think off.
I'm sure I've mailed that XSpower before and they never replied...
hope this helps
Hi,
Looking at the design of the manifold i believe it would foul stuff on the rhd s3,it's of a similar design to the atp kit which also suffers from the same problem.It looks like it's aimed at the lhd market .Stainless manifolds also have a nasty habit of cracking and need good bracing.You may be able to run a adapter to move the turbo but would sacrifice flow,cheap though.
As Ryan says, LHD fitment kits rarely fit RHD cars, mainly because the master cyclinder and servo .etc are in the way for the downpipe. Its much easier (but much more expensive) to go for a UK kit.
Rich
it also doesn't run much boost, internal wastegate 8.3 psi which is virtually stock, which also raises questions about intercooler quality on what seems to be a very very comprehensive kit for not much cash,
if its gonna produce power its going to be laggy you'd be better of with a k04 and injectors imo
or doing something like Rich's beast
37
19K
972
16
3K
