Results 1 to 9 of 9
    Jun 2003
    133
    MTM Mov\'it v\'s AMD Brembo brakes
    How do u think these brakes compare, do u think that the Mov'it brakes are worth the extra Ł800
    [img]/ubbthreads/images/graemlins/froggie_red.gif[/img]
    May 2003
    South East
    116
    Re: MTM Mov\'it v\'s AMD Brembo brakes
    the movits are probably worth the extra if you do lots of track days as the Movits (similar to the porsche 993 tt kit) will offer better fade resistance. IIRC the AMD brembo kit has smaller calipers (like mine) and doesn't use the drilled discs.
    up your arse
    37
    Not sure if its diff on the S3 but Movit and AMD brakes are both made by Brembo and are the same calipers and same disks....unless I'm wrong. But on my TT there were identical.
    Jun 2003
    133
    Well is the mov'it a better disk/caliper ie. made from better materials or are u saying that the brembo and movit disc/caliper are basicly the same and they are charging twice as much for the mov'it.
    UK
    289
    depends what Brembo brakes you are referring too - the Porsche ones (same as Movits) or the Brembo brakes that come from the Cupra R, which the TT Forum had a group buy on recently? All are four pot, but as Simon says the Porsche/Movit ones use drilled disc and a slightly bigger caliper
    All made by Brembo though
    Dunc
    Administrators's Avatar
    Administrator
    Oxfordshire
    1,000,002,023
    Follow Administrators On Twitter
    [ QUOTE ]
    [/ QUOTE ]
    Simon, looks drilled to me!
    I'm using these on my Golf at the moment and haven't even seen the slighest bit of fade yet!
    We do however offer a similar upgrade to the movits, have a look here and compare
    Jun 2003
    133
    Ahh well that answers my question the AMD Brembo disks dont compare to the mov'its if you are offering another disk to rival the mov'it disk.
    How much are the Porsche 993 bi-turbo discs + Calipers for For 16/17" rims with minimum 365mm ID
    Administrator
    Oxfordshire
    1,000,002,023
    At the spec you're looking at it would be Ł1475 +VAT +Fitting
    May 2003
    South East
    116
    Sorry forgot that the brembo kit offered the drilled - i've got the grooved. IIRC, the brembo disc offered by AMD is 28mm and is a single piece unit compared to the movit/porsche discs which are drilled 2 piece floating bell design with 32mm thickness
