Sky InsuranceChris Nott
Results 1 to 7 of 7
    Danman1's Avatar
    Thorough noob
    Sep 2011
    West Midlands
    338
    Top mount replacement help.
    I am about to replace my front top mounts on my 2002 S3. I've searched and read some threads (including Tufftys) on this but was wondering if someone could spell out how the front suspension strut is removed/direct me to a guide.
    What tools are needed and what parts. I already have the rubber mounts with new bearings do I need anything else?
    Dan
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Just to add a questions, can this be done with the damper in situ? Ive got collies and want to inspect my top mounts but cant be arsed remocing the entire set up?
    Oct 2010
    Hampshire
    294
    I'm planning to do mine this weekend. Would also like to know if you could use spring compressors and avoid disconnecting the lower suspension. Will tracking need redoing?
    I just have a rubber top mount and bearing for each side. Pair of spring compressors are the only specific tool i have.
    A guide here Noah's MkIV VW H&R Coilover Installation HOWTO
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,558
    Need to remove the strut Dani...
    You ideally need a special tool to spread the hub to get the strut out and spring compressors if not coil overs...
    This guide will help but you do NOT need to drop/undo the subframe to do it like is suggested...
    MKIV Jetta Suspension Installation
    <tuffty/>
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Aww thats poo. Fmic in the sun it is haha.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    You can change them without removing the strut IF you have coilovers...plenty of room just drop the ARB link..
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Ill look into if i get chance, thanks for the heads up dave.
  1. Front top mount fitting help...
    By s3dave in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st September 2011, 09:56
  2. Replacement bumpstops and top mounts - stockists?
    By munchkincoupe in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th December 2010, 22:11
  3. Coilover swap-out - WORTH REPLACING TOP MOUNT RUBBERS?
    By Indie_DSG in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st March 2010, 17:16
  4. Replacing the top mounts
    By Nilz in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2008, 15:50
  5. Replacement Rear Top Mounts
    By Phantom_A4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd October 2006, 23:24
