Volks AutosAH Fabrications
Results 1 to 8 of 8
    Jul 2005
    Kent
    29
    Bloody Audi electrics
    I thought Alfa Romeos were bad (I had a GTV). But I'm sick and tired of all the dodgy electronic issues I've had in the last 6 months.
    - Instrument cluster doesn't work in the cold (maybe bad solder joint??)
    - Alarm goes off randomly - its now sitting in my company carpark unlocked/unarmed
    - Amplified aerial failed
    The car is just 4 years old so am I just unlucky??
    Carlos
    necroeire's Avatar
    Feb 2004
    Ireland
    1,003
    Re: Bloody Audi electrics
    Don't know mate I had the instruments fail too and my car is just 3 years old!!!!!!
    A few people have had the same thing.
    paul_brad's Avatar
    Apr 2004
    Leicester
    365
    I think you must be unlucky!
    My 5 year old A3 is in perfect condition in the electronics department... apart from DIS has a couple of lines missing...
    Generally, audis are going to be better than most makes. Percentage wise. But there will always be a percentage that continually go wrong I guess.
    (I sometimes think about getting a GTV, but then get scared by the potential nightmare I might have with it)
    Oct 2005
    wirral
    45
    just incase u didnt no i about 99% certain audi will pay 50% towards dash replacment due to to fading dis on good will. could b wrong but if it really bothers u 50% is probably a couple of hundred bats.
    Jun 2003
    World of my own
    9,813
    If you get a GTV make sure you opt for the spare engine bundle, you'll need it.
    The Slug's Avatar
    Nov 2004
    UK
    1,853
    lol, would that be the Fiat engine bundle
    Jul 2005
    Kent
    29
    The problem is that there are no companies out there who fix clusters.. the only solution is a swap out, which wil cost the best part of a grand (inc. fitting and coding).
    But I might try the Audi UK route because it is ridiculous that this should happen to a 4 year old car. And it is not just me but many other Audi owners (especially TTs which also have the Jaeger instrument cluster). When you trawl through the forums it always ends up as a replacement on warranty, but for me it is out of warranty.
    Carlos
    The Slug's Avatar
    Nov 2004
    UK
    1,853
    I noticed once that my door locks wasnt flashing, turned out to be the passenger( missus) door wasnt shut properly, hopes this helps anyone else, simple error, women hey!! tut
