AH FabricationsChris Nott
Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By Danman1
Thread: S3 door blade removal guide with pictures.
    Danman1's Avatar
    Thorough noob
    Sep 2011
    West Midlands
    338
    Removed my door blades today, thought i'd give them a good clean and see if I had any dreaded rust behind them. As I went I took a few pictures, I know it's an easy job that probably doesn't need a guide but I was bored.
    Start by removing the 4 screws on the bottom of the door, 2 are behind rubber grommets.
    When the 4 screws are out, slide the door blade towards the back of the car, mine was really stiff and I didn't want to hit it too hard incase I broke the lugs off, but after rocking it back and forth it came off. When it was off you can see all the dirt behind it, and at first I thought I had the rust but it washed off.
    Dirty.
    After a good clean, applied a little waxoyl to prevent ant future rusting.
    Then gave the blade a good clean
    The rear blades just slide off, you slide them towards the front of the car. No screws holding these on. These were also stiff, just wacked them with my hand a few times and it popped off.
    Overall and easy job, I would recommend having one of those telescopic pens with the powerful magnet on the end so that if you do lose a screw in the door it's easy to retrieve.
    Darren4 likes this.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,156
    Thanks for this. I'll take mine off when I clay bar it before inters.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Thanks for such a nicely and well put together guide.
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,640
    I have been thinking about wrapping mine in gloss black or carbon, but thought it was a pain to take off, but after seeing this, it doesnt look so bad now
    Excellent write up bud.
    Feb 2008
    2,810
    Got to do this myself jus waiting for the weather. Many thanks.
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
    Danman1's Avatar
    Thorough noob
    Sep 2011
    West Midlands
    338
    Cheers guys, yeah it is literally a 30 minute job.
    Mar 2012
    131
    Quote Originally Posted by Nilz View Post
    There is another recent thread where the owner has wrapped the blades in Carbon and it looks great :-)
    Martin
    S3 2003 Avus Silver, Sunroof, Chrome Mirrors, Symphony II, Cruise, Heated Seats, Centre Armrest, Ambient Lights, GTRS Turbo, Forge FMIC, Sports Cats, MillTek, Coilovers ...
    Jun 2012
    11
    Has anyone had a problems getting the screws out, to do this?
    My pas door blade is becoming un-glued between the bit that is screwed on and the external part, i wanted to take it off give a dam good clean up then reglue it and refit but. but on mine these screws are extremely tight!!
    the outer one (easiest to get at) has now broken the white plastic strip on the outer edge of the door because the nut spun in it as i was trying to undo it.
    plus the ones in the door don't nicely line up with the hole to put the screw driver through so they look like they are going to round off
    JtotheD's Avatar
    Events Moderator
    May 2011
    Bournemouth, Dorset/ Wallingord, Oxon
    907
    Nice guide I'll definitely be giving this a go later!
    S3 8L Ming Blue 273bhp & 294lbft h
    Build/project thread
    check it out!
    Danman1's Avatar
    Thorough noob
    Sep 2011
    West Midlands
    338
    Quote Originally Posted by TomCrox41 View Post
    Yes, when I did the guide one of the screws was seized and i couldn't get it off, had to drill it out. Easy if you have a drill and a metal bit.
    Dan
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,175
    Here's how I fixed my passenger side blade that had started coming away from the door:
    Attempting door blade removal later today
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,522
    Anyone got part number for the screws?
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,078
    Good shout, another job for the weekend.
    Nov 2011
    138
    I had a nightmare with this yesterday
    my drivers side blade was pretty much hanging off, so i thought i'd give it a go taking it off.
    straight from the off, i WD40'd all of the screws in hope it would help, only one screw actually came out, the other three were stuck (it seems that someone had attempted this before as well, 2 of the screw in points on the blade had rounded off and come away from the white plastic bit in the blade itself and there was a random long screw going through the door straight into the blade, which was also too long and poking through the outside of the blade). i eventually managed to get the blade off the door but the white plastic bit was in pieces and not even attached to the door blade
    i was then left with the prospect of somehow removing the screws from the door as they are just hanging loosely, i managed to eventually get 2 of them off, but i'm now left with one screw still in situ and some duct taped holes to stop water ingress.
    i don't really know what to do i guess it's a case of buying a new blade (the passengers side is almost as bad so i may as well get both) i take it you can't buy a replacement white plastic insert?
    James
    Nov 2011
    138
    any help guys?
    Sep 2006
    Sunny Suffolk
    550
    Does anyone have the part number of the rubber grommets/bungs?
  1. Attempting door blade removal later today
    By The Doctor in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2013, 14:47
  2. Door blade removal tips
    By S3MVR in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th May 2012, 21:44
  3. Wiper Blade Removal
    By mystic.bertie in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th December 2011, 16:33
  4. Door mirror removal guide?
    By pdv40 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th September 2009, 17:32
  5. Rear Light Removal 3 door -Guide?
    By Mikey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th July 2008, 16:36
Tags for this Thread
