Sky InsuranceBadger5
Like Tree1Likes
  • 1 Post By bengal
Thread: 1.8T AUM split hose problem?
    Oct 2011
    Edinburgh
    144
    Question 1.8T AUM split hose problem?
    I was topping up the washer fluid on my car today and noticed I could hear a slight hissing at idle. I had a quick look over the engine and noticed that this hose running from the intake manifold had a split in it. As a temporary measure I've wrapped it with insulating tape which seems to have sealed it and got rid of the hissing - but wondered if anyone know what this hose was or what it did??
    thanks for any help/advice!
    * 2013 BMW 116d M Sport: current
    * 2002 Audi A3 1.8T Sport (8L): current
    * 2003 Mercedes Benz C200K Avantgarde SE (W203): current
    * 1998 BMW Z3 2.8 Roadster (E36/7): now sold
    * 1998 BMW 316i Compact (E36): now crushed!!
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    That would be the vacuum pipe for the brake servo, I'd get it changed asap else you will end up in trouble if you need to slam the brakes on.
    It's a main dealer only part and it should have a part no on it somewhere.
    pangsterA3 likes this.
    Oct 2011
    Edinburgh
    144
    Quote Originally Posted by bengal View Post
    excellent!! - thanks for the quick reply Bengal!! - I'll get one ordered pronto.. if I get a chance I'll really need to give all the hoses a proper once over as I would imagine that there might be more on the verge of splitting!
    thanks again for the help!
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    No problem, as for the rest of the pipes, if they look like they've been on for a while then I would change them all just to be sure as 99% of my running problems have been down to the maze of vacuum pipes in the engine bay.
    Silicone hoses are the way forward if you don't mind paying a bit more than the rubber ones.
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Get that changed as soon as possible! Mines split all the way along and ive got no brakes at all! The entire pipe was quoted at 60 from tps
    Audi A3 1.8t AUM
    Forge 007p, Pipercross Panel Filter, Eibach Prokit 35mm drop, EBC Green Stuff Pads
    Groved Disks, HEL Braided Brake Lines with Dot 5.1 fluid.
    Creation Motorsport Silicone TIP,
    N75 hoses, DV Hose & 10mm Rear Wheel Spacers
    Powerflex Rear Beam Bushes & Diesel Dog Bone Bush
    8k HID Kit, 8k LED Side Lights, 8k Number Plate LED
  1. Can anyone help with this split hose?
    By s3speedpluscomfort in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th June 2011, 21:50
  2. Split hose :(
    By 5teve L in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st June 2010, 18:04
  3. Split Hose
    By Danny Cawsey in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th April 2010, 22:20
  4. Split Fuel Hose
    By Stringster in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st December 2007, 01:21
  5. Split hose
    By pablo in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th October 2006, 12:14
