EM TuningSky Insurance
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    Question Coolant pipe part number HELP please
    The coolant pipe which runs just above the plastic undertray located at the very front of the car, part metal and part a hard rubber, part of the coolant system, which is prone to leaking I believe, anyone know the part number so I can order one from Audi? Found my leak and this is the culprit!
    When changing it too, will I need to drain the system or just blank the ends off with my fingers? If the system needs draining, how much G12 coolant is needed?
    2002 225 S3, metallic black, REVO, 18" RSTT alloys, goodyear Eagle F1s, silver leather heated seats, tinted windows, H&R spacers, black diamond grooved discs & Ferrodo DS2500 pads, BOSE system, xenons, forge DV, samco TIP & upper boost hoses.
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    Anyone!?
    Apr 2012
    N. Wales, LL22
    1,224
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    What a guy! Thanks very much mate
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    Quote Originally Posted by campbell View Post
    Just re-read this... the only coolant pipe I recall running along the bottom is the one from the thermostat housing and the bottom of the radiator... this is purly rubber... you haven't mistaken the power steering pipes for coolant pipes have you?
    The only coolant hose I know of that is part metal/part rubber is the one from the afterrun pump to the turbo that runs along the side of the cambelt cover and goes round the back of the engine..
    <tuffty/>
  1. Coolant Leak... Help with part name/number
    By Maz in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2012, 13:17
  2. water leak on a metal coolant pipe (cant find the part number)
    By rozsy in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th April 2011, 20:55
  3. What does this pipe do!? Part number please
    By finesse in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th April 2010, 10:49
  4. Tear in pipe - part number???
    By kitpayne in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2009, 17:22
  5. Coolant leak (part number)
    By Mick a3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd July 2009, 18:15
