AH FabricationsChris Nott
    Feb 2011
    Somerset
    238
    Fault code help.
    On my way to work this morning my mil light came on, when I checked it with my code reader it said, PO172 system over rich bank one, does anyone have any idea what it means and what the cause could be, I cleared the code, then went for a blast and all is well, thanks for any help.
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,287
    I had this, my mate come out with vag com asked me where I'd bin, told him work then petrol station, he cleared code went to my fuel cap tighten it a click then said there sorted and light not bin back n since, this was 2 weeks ago.
    Feb 2011
    Somerset
    238
    Thanks for that, funny enough, I got petrol the night before, I just went out and tightened my cap a few clicks too, just have to wait and see what happens now, cheers.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    16556/P0172/000370 - Ross-Tech Wiki
    16556/P0172 - System Too Rich, Bank 1
    Possible Symptoms
    Irregular behaviour
    Possible Causes
    Fuel system
    Excessive fuel pressure
    Leaking or contaminated fuel injectors
    Leaking fuel pressure regulator
    Low fuel pressure or running out of fuel
    Vapor recovery system
    Air leaks after the MAF
    Vacuum leaks
    Improper seated engine oil dipstick
    Stuck EGR valve
    Oil overfill
    Cam timing
    Cylinder compression
    Exhaust leaks before or near HO2Ss.
    Seen this before on BAM engined S3's... what year is your car?
    In the cases I have seen the rubber fuel hoses rot and the 'stuff' collects in the FPR giving increased fuel pressure and thus the too rich fault code...
    Looks like this...
    <tuffty/>
    Feb 2011
    Somerset
    238
    Wow now that's a big list thanks, the car is an A3T 2001 with AUM.
    Feb 2011
    Somerset
    238
    Quick update, I did 360 miles since I wiped the code from the ecu and still no probs, thanks for info chaps :-)
  1. I got a fault code - help please. Code 18057.
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2011, 10:29
  2. Replies: 2
    Last Post: 19th December 2010, 20:41
  3. Replies: 5
    Last Post: 18th January 2010, 23:36
  4. fault code help
    By Audi_nut in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th May 2008, 20:33
  5. possible fault code?
    By killa_z in forum VCDS (formerly VAG-COM) forum
    Last Post: 28th November 2007, 00:58
