EM TuningVolks Autos
    Nov 2004
    South London
    237
    Brake fluid change
    My car is just approaching 19k miles - am I right in thinking the brake fluid needs to be changed at some point soon?
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Oct 2005
    wirral
    45
    Re: Brake fluid change
    audi recomend the brake fluid is changed every 2 years. there is no recomended mielage interval.
    imported_fingermouse
    i had my last car nearly 9 years and never changed the brake fluid. only time new got add3ed was when i changed the rear calipers and overhauled the front pistons.
    I think they can test the fluid to see if it needs doing ???
    imported_Pures3work
    It's every 2 years. Or if you boil the brake fluid by giving it some and braking hard, you best get it done sooner.
    I did mine after 19months as the brakes had gone a tad spongy.
    Nov 2004
    South London
    237
    Ok, thanks for the replies guys. Is it the haldex oil that needs changing at 20k miles then?
