AH FabricationsChris Nott
    Jan 2012
    41
    HELP oil leak ?? 98 agu 1.8t ???oil filter housing or oil cooler??
    Anyone help I had my oil pick up replaced as had the dreaded oil pressure warning light and ever since I've had this oil leak when car is running, I get a oil build up just above sump on front of block on the lip which in time fills upp and runs down from of sump, I replaced oil filter housing gasket and oil cooler gasket but still no joy the oil is defo coming from near oil filter housing and it's not above it it anything ?? Confused and very frustrated anyone have a idea what it could be as don't want to keep throwing money at it hoping somebody knows where oil is coming from????
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Pics might help buddy...sure it's not the sump gasket?
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
    Jan 2012
    41
    Nag thought that but it's not as it's coming from above and building up on ledge above where sump bolts bolt up onto right by oil filter housing
    Jan 2012
    41
    Wondering if the cooler may be cracked or the housing itself ??? Anyone help getting rather annoyed with it now
  1. Oil filter housing breather hose question-BOOST LEAK?
    By Scullies in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th March 2012, 19:52
  2. Newbie 'What type of Oil' question
    By bluerouter in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd March 2011, 08:28
  3. Oil leak from turbo inter cooler
    By john24susan in forum Diesel forum
    Last Post: 29th April 2009, 11:52
  4. 'oil' flashes on start up
    By a4cam in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th January 2008, 15:55
  5. Is there a valve in the oil filter and cooler?
    By S3Si in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th December 2005, 12:44
