Chris NottAH Fabrications
Results 1 to 15 of 15
Thread: k04 manifold
    Audakas's Avatar
    Mar 2011
    London Wembley
    91
    k04 manifold
    Hi my xs power manifold just craked again 3rd time after re welding 2 times im sick of it. shall i stick whit original k04 manifold or go for expensive jbs wondering what advantages i would have?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    www.badger5.co.uk
    May 2004
    nr Glos
    6,935
    Quote Originally Posted by Audakas View Post
    Version 1 or version 2
    cracked where exactly?
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,156
    That's bad. Only seen Prawn's crack and he seriously abuses his car. What are you doing to your car
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    www.badger5.co.uk
    May 2004
    nr Glos
    6,935
    XS/Relentless mani's have been cracking for a long time Neil... its not unique to prawn...
    hoping V2 is going to be more robust.... but...... time will tell on that score
    bill@badger5.co.uk
    Westy's Avatar
    Dec 2008
    17,156
    That may be the case Bill but there's a lot of these manis on cars now and the reports of them cracking haven't been that common. Especially not on here and especially not 3 times!
    S3 Build Thread
    Jimgrim77's Avatar
    Nov 2011
    Clevedon, Near Bristol
    957
    Not version 2's...yet. V1's plenty.
    Still not sure which version here has cracked though. Hoping v1.
    Ming Blue S3, Stage 3 Hybrid Turbo, Custom Map, Bosch 480 injectors, Custom TIP, Forge FMIC, 3" Downpipe, 200 Cell Sport CAT, Full Stainless, XS Power Mani, 6 Paddle Clutch, Red silicone hoses, LCR Brembo's, Forge 007p, KW Suspension Kit, Green filter, THS Mounts, 11mm & 16mm spacers, H&R Anti-roll bars, RS6 18" alloys, Michelin PS3's, Red Dog Bone Mount, Neuspeed quickshift, Boost Gauge, Aero wipers, LCR splitter, Forge Tie-bars, LED bulbs, Armrest, Custom TT pedals.
    www.badger5.co.uk
    May 2004
    nr Glos
    6,935
    Quote Originally Posted by Westy View Post
    V2's have not been running on cars very long yet............
    fingers crossed of course but......
    bill@badger5.co.uk
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,055
    3 times on the same manifold is meaningless though westy, as a repaired weld is never going to be as good as te original, so it'll always go again
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,055
    If they were welded with rod that is, the V1s looked to have a lot of there joins fused in with no rod,,, to make them look pretty no doubt...
    Westy's Avatar
    Dec 2008
    17,156
    Also cheaper to make I assume Dave?
    S3 Build Thread
    www.badger5.co.uk
    May 2004
    nr Glos
    6,935
    thing is Dave... so are the V2's in many joins. Fusion only welding is fine if back purged and fully penetrative which they are'nt. I used to make coriolis mass flow meters which were C22 or 316L tubular instruments, which we orbitally welded.... 100% penetration, perfect fusion only welds. Post weld vacuum annealed however to normalise the materials and welds.. On tensile tests when I qualified the weld process, the tubes would break everywhere except the weld joint.
    I have had 3 relentless manifolds sent here in last 2 weeks.... for welding before fitting. fusion welds on the runners, and some filler on the collector area seems the norm. they have gone "tink" "tink" when welding... from localised expansion. Hope they work ok in service. Fitted 2 to 2 cars in the last 2 weeks also.. PIA that they are to fit, lol
    I think we're all hoping they hold out a reasonable time..... but I am realistic that their construction methods dont help that cause.. but am happily proved wrong, as they flow very well.
    bill@badger5.co.uk
    Jimgrim77's Avatar
    Nov 2011
    957
    I suspect that they will crack if subjected to insane temperatures with regularity.
    Many users seem to be cranking up their maps and perhaps going too aggressive.
    Anyone having their car tuned without someone really knowing what they are doing are at risk with this part, it's as simple as that.
    We've been closely monitoring the temperature on mine because it was running was too hot, but I've been checking it almost weekly for 4 months. I doubt whether many others will be able to be so thorough.
    Audakas's Avatar
    Mar 2011
    London Wembley
    91
    i abuse my car aswell but only sometimes. but i think that v1 not to sure. but when i fitted after three weeks. its cracked re welded again another couple weeks cracked an fact i have a turbo timer set all the time to let the turbo cool down whit manifold im really disappointed probably gonna use the standard manifold.
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,055
    Quote Originally Posted by Jimgrim77 View Post
    well that's me ****ed then isn't it!
    Mine cracked on a trackday on actuator pressure, you can't turn the boost down any further :P
  1. So the JBS K04 Manifold is out...
    By Yohan87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th April 2012, 13:26
  2. Turbo To Exhaust Manifold Gasket & Manifold Gasket :(
    By Dazboss in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2012, 14:42
  3. THS MANIFOLD
    By jamie226bhp in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th January 2010, 21:14
  4. ATP manifold
    By kenny_boon in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th July 2006, 10:41
