AH FabricationsVolks Autos
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Angry Haldex oil change cockup!
    Hi
    I put the car on ramps and changed the haldex filter and oil, the job was pretty easy, didn't lose much oil when I put the new plug and washer on.
    Torqued it up to 15nm as per the manual.
    Cleaned the area afterwards to look for leaks and noticed this
    New washer time?
    Has this happened to anyone before?
    Should I drop the oil and put in a known amount again seeing as I'll lose a bit more if I change the washer?
    Help?
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,559
    I know there is supposed to be a torque applied to most things but common sense should prevail here realistically... last haldex plug that got torqued up I know of resulted in stripped threads...
    The torque arguably applies when its all new and shiny but once over a certain age and of course after its been off a few times then tbh torquing the plug up is less appealing... you get a better feel doing it by hand tbh...
    Doesn't look like its leaking yet
    <tuffty/>
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Thanks. Now I know!
    I went for a bit of a drive on a short loop and it's weeping slightly.
    It's a shame the GSF I'm in walking distance of doesn't sell the sump plug or washer
    Liam
    Jul 2007
    London
    3,235
    Why not get a suitable penny copper washer and change it ? Halfords do a wide selection and i'm sure you an get a decent selection from a plumbase or good plumber supplier ! As per above post, i trust my hand more than i trust a calibrated torque wrench !
    FOR SALE:
  1. Haldex Oil Change
    By treefrog73 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th April 2011, 14:17
  2. 8P S3 Haldex Oil Change
    By KRL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th April 2010, 15:17
  3. Haldex oil change
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th December 2009, 23:30
  4. Haldex oil change
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd May 2004, 09:32
