Chris NottAH Fabrications
    S3 Paul's Avatar
    Oct 2006
    2,759
    If the post cat lambda probe has been turned off in my map...
    My car is using CustomCode phase 3 mapping which has the post cat lambda turned off ( cat bypass fitted ) ive got a AFR gauge fitted and the wideband sensor for that is fitted just before the post cat lambda...
    The question is ... if the sensor is "turned off" in the map does it still need to be plugged in?
    Noggy Blue 2001 S3
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    Normally all thats turned off on post cat lambda is diagnostics... removing it completely is a little more involved mapping wise and isn't something that tends to get done...
    You have to turn off the probe ageing param, heater diagnosis and a few other constants I can't think of off hand...
    Just as easy to leave it plugged in mate tbh...
    <tuffty/>
    beachbuggy's Avatar
    Surrey
    1,727
    Quote Originally Posted by S3 Paul View Post
    I turned mine off completely, it's not plugged in and no errors come up. Just running the front lambda . If you don't get all the variables and constants then it needs to be plugged in to stop throwing errors. It's easily enough done.
  1. A strange question regarding my AFR gauge and lambda probe...
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th November 2011, 18:39
  2. stuck lambda probe
    By finesse in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th October 2010, 15:29
  3. lambda probe conundrum
    By kevandalice in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2010, 22:00
  4. lambda probe where is it ?
    By davidjohngarty@yahoo.co.u in forum TT/TT-S/TT-RS Forum
    Last Post: 9th November 2007, 11:16
  5. Lambda probe
    By robonmac in forum Classic Audi Forum
    Last Post: 1st April 2007, 23:25
