Chris NottVolks Autos
    Jan 2012
    Tamworth
    59
    Fault: Code P1297
    After seeing the eml light illuminate on my dashboard, I thought id read the memory to see what I could find. It threw up: Pressure drop between turbon and throttle valve. (P1297)
    Could someone inform me on how to cure this fault.
    Aug 2010
    1,540
    one of the most common fault codes ever to be seen on 1.8t engines.
    unfortunatly one of the most vaugest too.....
    check for air leaks everywhere/anywhere. if you cant see any, then most likely is the airmass is over reading.
    good luck!
  1. P1297 / 17705 - something different?
    By Craig1.8t in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd January 2012, 19:22
  2. I got a fault code - help please. Code 18057.
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2011, 10:29
  3. Replies: 2
    Last Post: 19th December 2010, 20:41
  4. S3 BAM - FAULT CODE P1297 - Intermittent Misfire at 2000RPM
    By ghill in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th December 2010, 22:25
  5. Replies: 5
    Last Post: 18th January 2010, 23:36
