Sky InsuranceChris Nott
Results 1 to 13 of 13
    Jul 2011
    middlesbrough
    112
    Powerflex engine dog bone bush?
    My original rubber bush was past its best could feel the engine rocking when i came on and off the accellerator. I changed it today for powerflex polyurathane bush its a a3 1.8t. But it feels different car car seems to vibrate alot more if that makes sense and when i come to a junction and still moving i pull out in second before it was fine now whole car shakes.. I have only done a few miles with it in will it bed it or stay like this? I think i will put a new standard one back in if they are always like this...
    Regards Tom
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,477
    They settle down after a while...
    <tuffty/>
    Markeyboy's Avatar
    Fan of the R-Tech!
    Aug 2011
    Thurrock, Essex
    281
    what colour did you go for red or yellow?
    as said they do soften up a bit, have heard if you tighten up the dogbone centre bolt to much can also cause a harsher ride
    1.8T SPORT AUM
    18" TTRS wheels, de-badged grill, tints, TIP, forge 007P, toyo sports oil catch can,
    3" downpipe + decat, Toyosports FMIC, 10mm lowering cups, N249 bypass
    S3 Front Brake Setup, R-Tech stage 1.5 custom remap 218BHP@229FT/LB
    Progression Thread
    http://www.audi-sport.net/vb/a3-s3-f...8t-thread.html
    Jul 2011
    middlesbrough
    112
    haha i tightened it till i couldnt anymore really just gave it a good nip and its yellow in colour cant say i realised they were different..
    BÜBENGRÖPEN
    Dec 2008
    Warrington
    742
    One of the best mods I did to my car
    Kristian
    No longer an Audi driver...
    Dan-Jnr's Avatar
    Jun 2011
    Manchester
    671
    The red bush isn't as harsh as the yellow one.
    2007 - Imola Yellow- Audi S3 - 305
    [8L BLOG] [8P BLOG]
    Oct 2011
    759
    Yellow needs to be 12lb of torque on the main bolt or your teeth will start to fallout.
    Alex C's Avatar
    Lizard, Cornwall
    2,595
    what should you torque the red one to?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    288
    You should have bought the red one that powerflex specify for diesel A3's. I replaced my std s3 one with the red powerflex and the car changes gear and drives much better now! Best £20 i've spent on the car I think!
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    288
    Quote Originally Posted by Alex C View Post
    13mm bolts should be 20Nm.
    16mm bolts should be 40Nm.
    The compression nut should be 20Nm + 1/4 turn.
    Oct 2011
    759
    clean all of the old bush out of the mount it makes a difference.
    then tighten as above, slight vibration at first (red bush) but soon settles down (200 miles or so)
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    I have a similar problem with my diesel bush, car vibrates a lot more, the mount was fully cleaned and torqued up correctly. The guys at the turbo unit in Tamworth suggested it could be my dual mass on its way out but that's a 'could' I won't know untill its changed.
    Audi A3 1.8t AUM
    Forge 007p, Pipercross Panel Filter, Eibach Prokit 35mm drop, EBC Green Stuff Pads
    Groved Disks, HEL Braided Brake Lines with Dot 5.1 fluid.
    Creation Motorsport Silicone TIP,
    N75 hoses, DV Hose & 10mm Rear Wheel Spacers
    Powerflex Rear Beam Bushes & Diesel Dog Bone Bush
    8k HID Kit, 8k LED Side Lights, 8k Number Plate LED
    Jul 2011
    middlesbrough
    112
    cheers for the help. i havnt done couple hunerd miles yet soon as i have if its no better i will take it all apart again and make sure its spick and span then torque to above not torqued to "fookin tight"
  1. dog bone bush best one ?
    By Daniel Thomson in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th January 2012, 16:06
  2. Mk1 A3 - Powerflex Front Dog Bone Mount Bush
    By AwesomeMike in forum Awesome GTI
    Last Post: 16th February 2011, 12:01
  3. OEM S3 Engine Dog Bone Bush PART NUMBER PLEASE
    By finesse in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2010, 17:00
  4. S3 Powerflex Dog Bone Fitted. Impressions
    By leecs3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th November 2007, 02:50
  5. Powerflex dog bone mount and low speed Judder?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th April 2005, 15:59
