EM TuningChris Nott
Results 1 to 7 of 7
Thread: lambda sensor
    Apr 2011
    London, United Kingdom, United Kingdom
    115
    lambda sensor
    i scanned my car with vag.com and came up with a lambda fault. i brought a bosch replacement about 8 months ago from euro car parts. does anyone know if it would be replaced under warranty?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    What was the actual fault code?
    <tuffty/>
    Apr 2011
    115
    16514, 16519, 00561 and 00543
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Can't find all the references on Ross Tech wiki... pasting the actual scan results would be useful...
    Found a couple though...
    00561 - Ross-Tech Wiki
    00561 - Mixture Adaptation: Adaptation Limit (Add) Exceeded
    Possible Symptoms
    Engine Jolting
    Increased Fuel Consumption
    Poor Idling/Jolting
    Reduced Boost Pressure
    Possible Causes
    Mass Air Flow Sensor (G70) faulty
    Fuel Pressure too Low
    Leaks in Intake Air System and/or Exhaust System
    Injector(s) faulty (i.e. coked)
    Possible Solutions
    Refuel Vehicle
    Check Fuel System Pressure
    Check Mass Air Flow Sensor (G70)
    Check Intake Air System and Exhaust System for Leaks
    Check Injection Quantity
    Check Injector(s)
    16514/P0130/000304 - Ross-Tech Wiki
    6514/P0130/000304 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
    Possible Causes
    Oxygen (Lambda) Sensor Heating Bank 1 Sensor 1 faulty
    Possible Solutions
    Check Oxygen (Lambda) Sensor Heating Bank 1 Sensor 1
    <tuffty/>
    Apr 2011
    115
    yh was in the same boat. not got the full version so only showed some. i had to google the rest
    VAG-COM Version: Release 409.1-S
    Control Module Part Number: 06A 906 018 R
    Component and/or Version: 1.8L R4/5VT MOTR HS D06
    Software Coding: 04000
    Work Shop Code: WSC 00028
    6 Faults Found:
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    16519 - Shareware Version. To Decode all DTCs
    P0135 - 35-10 - Please Register/Activate - Intermittent
    16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
    P0130 - 35-10 - Please Register/Activate - Intermittent
    14-00 - Adaptation Limit (Add) Exceeded
    00543 - maximum speed exceeded
    00561 - Shareware Version. To Decode all DTCs
    12-00 - Please Register/Activate
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,639
    Which lambda sensor did you get as there are two on the S3, was it the one before or after the cat, i believe the one on the scan results is the one in the engine bay.
    I believe the part will have a 12 months warranty on it, so try and see how you get on.
    Apr 2011
    115
    should have said i've got an agu a3 so only have one but also got a decat as well
  1. Lambda sensor/oxygen Sensor
    By GemmaLouise in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2011, 12:36
  2. Help with Lambda sensor
    By teambeer in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th November 2010, 14:30
  3. Lambda sensor
    By Fuzzy felt in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th January 2010, 15:18
  4. Lambda sensor S6
    By crispin in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 9th May 2009, 03:52
  5. Lambda Sensor
    By Speedo in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd July 2004, 09:23
