Normally if an AGU then you use an AGU MAF sensor in a VR6 housing... if an AUM you would use the AUM sensor in an S3 housing... if mapped correctly then it would be scaled to suit... if you have an AGU and going from a std AGU MAF housing to a VR6 housing then you need to get your mapping redone...
well im doing my k04 conversion soon and will be using the vr6 maf housing and fitting my new maf element within it (thanks prawn)
but just replace the maf with what ur using now mate
In fairness though.. with a K04 conversion you 'should' be running a VR6 MAF tube and have a proper map thats scaled to suit (including larger injectors etc...)
