AH FabricationsBadger5
Results 1 to 12 of 12
    May 2011
    20
    the noise of doom. what to do what to do
    well my car started making a loud whining noise under boost yesterday and had it looked at today. looks like the turbo is on its way out. the bearing has a bit of play in it and the blades are catching the body under boost and causing the whine. its an AMK with 72k and currently mapped by jabbasport to 277 with graphs.
    what to do now...
    do i......
    fix it with a standard turbo and sell it.
    trade it in while its not smoking etc
    fix it with a big turbo and silly power with stronger bottom end etc.
    i had a decent chunk of money saved for a mk5 golf gti so either of the above options is definitely feasable its just which route to go down.
    i have to admit i dont know masses about turbos and whats best etc but im definitely open to options.
    please help me people
    Pushing the limits..
    Jan 2011
    Australia
    1,316
    Add Sevv on Facebook
    bigger turbo , stronger bottom end :P try to fix and sell your damaged turbo......
    S3 Paul's Avatar
    Oct 2006
    2,764
    Trade it in against a mk5 GTI.
    Noggy Blue 2001 S3
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    Other option is to by a reconditioned K04 turbo to fix the issue. You could sell you turbo, as long as it's crack free, to recoup some of the cash. I've seen recond turbos for £250 before.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Quote Originally Posted by Westy View Post
    And then get the jabba map removed and replaced with a decent map.
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    May 2011
    20
    Quote Originally Posted by Funk_Junky View Post
    yeah ive never been entirely happy with the Jabba map. its got a really short boost range and runs out of puff a bit.
    reallistically then.
    how much would i be looking at for stronger bottom end and a bigger turbo.
    just trying to weigh up my options
    thanks for the help guys
    Customboy's Avatar
    Jan 2012
    SE London
    836
    How long ago was the map done before the turbo had issues maybe u can speak to jabba and see if they sort something out for seeing u have used them already, if u trade it in feel sorry for the guy or gal who may buy it and how they would feel if they knew they had this problem I know my conscious wouldn't let me but heh that's just me and business is business, if u did buy the mk5 gti u would eventually buy mods on it so maybe get a nice bigger turbo look around for a bargin then get all the bits sorted and fall in love with your car again and blow most cars off the road, well whatever u decide good luck mate hope things get sorted
    p
    THE BLUE BEAST, TAKEN FROM ME, GONE BUT NOT FORGOTTEN
    RTECH STAGE 2 REMAP NOW RUNNING 223 BHP AND 253 FTLB OF TORQUE,
    SUBARU IMPREZA WRX ESTATE SOON TO BE RUNNING 340 BHP
    ANTI LAG/LAUNCH CONTROL/MAF LESS/ LOVE IT !!
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Not that it helps now, but the map was probably the cause of your problems. I only say this as I used to have a map from them.
    Its worth reading the stickies on here for BT info, I wouldn't expect much change from ~£4k for a BT and new rods etc.
    > S3 225 (03) - OEM+
    View: My S3 diary
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    How sure are you that the turbo is at fault or the blades are catching? Sounds like a leaky exhaust manifold gasket or even a cracked manifold. Both cheaper to fix than a new turbo.
    May 2011
    20
    i thought it was leaking boost somewhere as it all started as soon as i changed the dump valve for a forge one. thought maybe i had split a hose but got it checked on monday and they tell me thats what it is so can only go by that really.
    Nov 2010
    1,673
    Ok mate, how well do you trust the garage? Not saying there conning you but its alot of money if there wrong.
    May 2011
    20
    hes a good lad and i deal with them a lot through work so dontthink hes having my pants down
    Martin
  1. Audi A3 1.8T (8l AUM Engine): Strange noise - grinding/rubbing noise..
    By pangsterA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th December 2011, 21:01
  2. Problem number 1 of ownership! Grinding noise and knocking noise help!!!!
    By gaznogaro2003 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th July 2010, 09:17
  3. Doom 3: Ressurection of Evil
    By TDI-line in forum Video Gaming
    Last Post: 28th July 2006, 14:53
  4. Doom 3
    By porker968 in forum Video Gaming
    Last Post: 20th August 2004, 15:28
  5. Popups of Doom
    By Gaunty in forum General Chat
    Last Post: 20th February 2003, 16:20
