Chris NottMonster Motorsport
Thread: My log results
    rhubarb4's Avatar
    Certified Jardo Slayer
    Mar 2008
    Midlands
    1,707
    My log results
    Hi guys just done a log with my new toy, can you look over it see if everything is ok or if something doesn't look right as I have no idea how to understand the readings or what they mean. Car is a 2001 AMK S3, as far as I know its standard bar the smoothed airbox.
    As I dont know how to post the readings up, I took pictures of my screen if they look a bit odd to you.
    I did 2 runs.
    Run 2 3rd gear redline.
    Run 1 3rd gear
    Thanks, Chris.
    <img src=http://cdn.as-static.com/vb/images/smilies/scared2.gif border=0 alt= title=Scared2 class=inlineimg />
    i wear ladies underwear to work.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,450
    looks like a healthy standard car to me
    rhubarb4's Avatar
    Mar 2008
    Midlands
    1,707
    Cheers Karl only fault code I had up was the dreaded lambda one 16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit P0130 - 35-10 so got some investigating to do, it's the first time Iv had that come up though.
    Chris
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,450
    Log the block for lambda. 031 maybe? Itl be in the stickies.
    But with that fault occuring it will be interesting to see if its meeting its requested, or its totally off.
    I think that code could just be a wiring fault
    rhubarb4's Avatar
    Mar 2008
    Midlands
    1,707
    Ok il try that after work tomorrow cheers i hope its not a wiring problem god knows where il have to start looking for that.
    Cheers, Chris.
  1. VAG COM RESULTS, CAN SOMEONE PLEASE HELP!!!!
    By rydinator in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2011, 13:31
  2. re-map... the results...
    By J45SON in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th January 2008, 17:53
  3. JBS RESULTS
    By Ballcrusher in forum Tuning
    Last Post: 21st April 2007, 17:44
  4. MPG Results
    By dickys3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st May 2006, 16:38
  5. My QST Results
    By Markey in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th March 2005, 07:49
