EM TuningJMB Retrofits
Thread: what is this??
    Dec 2011
    125
    what is this??
    Just found this and wasnt sure what is was. Also is the something missing as on one side us plugged in on the peice that look like a V connection. Thanks
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Im not sure which bit you are talking about, so ill take a stab.
    From left to right you have, Gear linkage selector, Clutch slave cylinder connector, passenger driveshaft.
    The slave cylinder looks fine, albeit a bit oiley.. The top connector is the feed from the master cylinder, and the bottom one is the bleed screw/valve.
