what is this??
John Spooner
NULL
Just found this and wasnt sure what is was. Also is the something missing as on one side us plugged in on the peice that look like a V connection. Thanks
Im not sure which bit you are talking about, so ill take a stab.
From left to right you have, Gear linkage selector, Clutch slave cylinder connector, passenger driveshaft.
The slave cylinder looks fine, albeit a bit oiley.. The top connector is the feed from the master cylinder, and the bottom one is the bleed screw/valve.
536
10
761
677
6
647
