EM TuningVolks Autos
Results 1 to 13 of 13
    s3 jack's Avatar
    Jun 2010
    cambs
    44
    changing dogbone bush (major fail)
    Ok so today i thought i would attack the dogbone bush which was on my long todo list and thought this would be an easy 20 miniut task. So i started undoing the 4 bolts, all fine untill i came to the last bolt the right hand one witch i think is bolted onto the subframe and the f**ker snaped , the head has come off this bolt leaving the threaded part in there.
    Any ideas on what i should do
    thanks jack
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,914
    Put a smaller drill bit in and drill it out
    s3 jack's Avatar
    Jun 2010
    cambs
    44
    i dont think ill be able to get a drill in at the right angle with out damaging the threads
    Aug 2011
    160
    Remove the subframe(which isn't too bad a job) heat up the bolt with a gas blow torch from B&Q and then use mole grips to work it loose.
    Audi A3 1.8T AUM Sport with more doors.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,914
    Quote Originally Posted by s3 jack View Post
    Can you not park up on a high kerb or drive onto boards to make it higher,then try and centre punch the middle and use a small drill bit.not easy granted.
    s3 jack's Avatar
    Jun 2010
    cambs
    44
    Voorhees i think i might have to try this, it is on axle stands at the min. What a major f**k up
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,282
    Head a few of these stories recently. Serious pita. I had a DP stud snap off a few months ago in the turbo and had to drill it out. Luckily there was just enough thread left to grip a new bolt.
    Good luck with getting this out mate.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Eddie S3's Avatar
    Jul 2011
    Aberdeen
    108
    I had the exact same thing happen to me when i tried changing mine, Lots of heat and molegrips worked a treat
    Jun 2010
    warwickshire
    93
    Always a good thing todo^^^^^.......Future ref penetratingfluid to hand and soak any bolts or nuts before attacking the job in hand(just a lil advice which ent no good till next time lol) good luck
    s3 jack's Avatar
    Jun 2010
    cambs
    44
    I did use penatrating fluid before i started but wouldnt budge it. I managed to get the dog bone out with a bit of force as lukily that isnt threaded, unfortunatley the bolt has shered off flush with the subframe so i cant even get a pair of grips in it.
    Has anyone ever used screw extractors and now if there any good
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Be careful. If you snap an extractor off in the stud it will be even more difficult as you cannot drill them easily.
    s3 jack's Avatar
    Jun 2010
    cambs
    44
    if its gana happen, its gana happen to me
    BENJAMIN's Avatar
    Mar 2011
    472
    This is really common on the dogbone mount! It's the bolt corroding to the alloy mount that makes the head snap off, heat the base of the mount up and drive a wedge between the subframe and base of the mount and lever it away. It will eventually slide off the snapped bolt. The snapped stud will simply unscrew by hand! I get this at least once a month on a3's and golfs. Steel bolt + alloy mount + 10 years of salt water, it's no surprise really! Lol
  1. red or yellow dogbone bush? cant remember
    By ANDYMC_TQS in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st December 2011, 13:17
  2. Dogbone bush
    By dannyh in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th September 2011, 08:38
  3. Dogbone Bush Problems!
    By [Dave B] in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th March 2011, 16:46
  4. Dogbone Bush
    By edition in forum DPM Performance
    Last Post: 17th February 2010, 13:58
  5. DogBone Mount Bush Replacement
    By mike_plymouth in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th June 2009, 19:43
