Sky InsuranceVolks Autos
Thread: ARB bush squeak
    Ginge's Avatar
    It's never fast enough !
    Jan 2011
    Hemel Hempstead (home) / Loughborough (UNI)
    192
    ARB bush squeak
    Ok so my rear arb bushes are squeaking like mad, it is thoroughly frustrating I promise you.
    I have replaced the bushes and drop links and coated everything with silicone lube.
    This stopped the squeak for about a week but now it is back again and it is definitely the ARB bushes.
    The question I have is can I shave off some of the inside of the bush to reduce some friction on the ARB. I can't see a problem with it but I thought I'd check before I break something
    Many thanks, Tom.
    99' S3 APY currently just 007p, Badger 5 TIP, Customised Miltek non-res cat-back, Jetex cone, H&R Springs and Bilstein B8 Dampers ... 3" Downpipe, AH Fabrications FMIC and R-Tech Re-map on the way
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    pretty sure you should be using grease not lube. I had to re-do mine a while ago usually stops it for atleast 6months but it is weather depentent.
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
  1. Squeak Squeak Squeak ... arrggghhh
    By Inertiauk in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2011, 21:36
  2. 1 squeak down, 99 to go.
    By cjhill in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2009, 21:53
  3. Squeak
    By dc240969 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th July 2009, 11:16
  4. Squeak when I start the car
    By Amchlolor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th April 2007, 13:13
  5. Squeak...
    By TQS in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th April 2006, 19:50
