Chris NottMonster Motorsport
Results 1 to 13 of 13
    Jan 2011
    Swansea
    73
    S3 8L Rear Brakes
    Hi,
    My rear brakes seem to be squeaking so I'm in the market to overhaul them a little. I've been looking at new discs and pads, any recommendations?
    Also, what do you think of these:
    REAR DRILLED GROOVED BRAKE DISCS BREMBO PADS AUDI A3 S3 QUATTRO 01 > | eBay
    Thank you
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    I did mine last weekend,changed to mintex disks and pads. Haven't had a chance to jump on the brakes as I'm still bedding them in. Is advise changing your fluid at the same time
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    Jan 2011
    Swansea
    73
    How difficult is a fluid change? I think I read a whole ago that it's quite tricky and may require two people!
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Just buy a eeziblees kit so you can do it yourself. Don't do the two man pedal pump
    Word!!!
    Jan 2011
    Swansea
    73
    Quote Originally Posted by Paradox1 View Post
    Ok Cheers mate
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Quote Originally Posted by cagiti View Post
    Mine squeal like little piggies on their way to market too.
    I have standard discs with Brembo branded pads.
    Can I just clean and grease the callipers or do I need new pads and disks?
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    Danman1's Avatar
    Thorough noob
    Sep 2011
    West Midlands
    338
    Hi,
    Thank you
    I've also seen those brakes on ebay, can any gurus give their opinions on them?
    Dan
    Feb 2006
    Lincolnshire
    723
    I put Pagid disks and pads on mine last weekend, apart from winding the pistons back in it was a straightforward job.
    I like the Pagid disks as they have a primer coating all over them and the pads take it off just on the disk part on the first activation. It will hopefully delay the onset of the unsightly disk hub rust.
    Audi S3 - 2002MY - Denim Blue - Gone
    VW Polo GTI - 2011MY - Candy White - Here
    Dan-Jnr's Avatar
    Jun 2011
    Manchester
    692
    Rears do not do a lot of braking so the standard S3 Pagid disc and pad will be sufficient.
    2007 - Imola Yellow- Audi S3 - 305
    [8L BLOG] [8P BLOG]
    Feb 2012
    34
    Did mine the other weekend too... Brembo pads with standard discs from GSF 60 quid for the lot.. Bit of squeal from the new set up but I'm sure it'll die down. Really easy job, just make sure you've got a right hand thread piston wind back tool and an 8mm hex tool and you'll be done in an hour!
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Quote Originally Posted by S3lvo View Post
    Yopu didnt take thew carriers off did you?
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    I have had these fitted for over 2 years and the discs are nearly needing a replacement but pads are over 50% thick:
    www.vwspares.co.uk
    www.vwspares.co.uk
    I try to avoid drilled discs and any discs that have thin grooves as they just get blocked with brake dust.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Feb 2012
    34
    Yeah, you need to to take the discs off. Plus, often after a while there's a build up of rust on the inner parts of the carriers so to get a good fit with the new pads it's a good idea to get a wire brush in there to get rid of some of the crud!
  1. NEW Golf Mk5 R32 / Audi S3 Front and Rear Brakes - 345mm Front and 310mm Vented Rear
    By DOLPHIN DIESEL in forum For Sale/Wanted - Audi Parts
    Last Post: 16th August 2011, 14:13
  2. Front Brakes/Rear Brakes
    By andrecc in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th July 2011, 10:59
  3. Rear brakes what to get...
    By wagon in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2010, 19:21
  4. a4 1.8t rear brakes
    By aragorn in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th February 2008, 23:57
  5. rear brakes
    By dantheman1986 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th June 2007, 15:24
