Results 1 to 15 of 15
    Danman1's Avatar
    Thorough noob
    Sep 2011
    West Midlands
    338
    Quick question about my S3
    I have a 2002 S3 and after i've turned the engine off i've noticed the small pump at the front of the engine doesnt make the usual noise it does like it used to. Should this always run for a short time after i've turned the engine off or is it dependent on something else? Also I read in the stickies it's a common fault to go, how much am I looking at for a new one?
    Dan
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,158
    This should always run after the car has been on as it pumps coolant round the turbo to cool it down. The most common thing to happen is the fuse blows. AFAIK it's the green fuse on the left of the 3 that are situated on top of the battery. It's a 30amp.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,846
    In can confirm that the pump runs even after I just move my car on my drive.
    You've got to have a laugh!
    Jimgrim77's Avatar
    Nov 2011
    Clevedon, Near Bristol
    957
    Mine runs as I turn the ignition over and for about 20 mins post drive to cool turbo.
    Fuse problem likely of connection.
    Easy fix and sort for turbo longevity.
    Ming Blue S3, Stage 3 Hybrid Turbo, Custom Map, Bosch 480 injectors, Custom TIP, Forge FMIC, 3" Downpipe, 200 Cell Sport CAT, Full Stainless, XS Power Mani, 6 Paddle Clutch, Red silicone hoses, LCR Brembo's, Forge 007p, KW Suspension Kit, Green filter, THS Mounts, 11mm & 16mm spacers, H&R Anti-roll bars, RS6 18" alloys, Michelin PS3's, Red Dog Bone Mount, Neuspeed quickshift, Boost Gauge, Aero wipers, LCR splitter, Forge Tie-bars, LED bulbs, Armrest, Custom TT pedals.
    Westy's Avatar
    Dec 2008
    17,158
    Oh I forgot to add. If it's the fuse then it will also effect the radiator fans that cut in at 100 degrees.
    S3 Build Thread
    Danman1's Avatar
    Thorough noob
    Sep 2011
    West Midlands
    338
    cheers guys, better sort it asap then.
    Danman1's Avatar
    Thorough noob
    Sep 2011
    West Midlands
    338
    Alright i've had a look and this is what i've got:
    the fuses 'look' ok, without getting a multimetre on them I can't be 100% sure. So the far left one is the pump one?
    Dan
    Westy's Avatar
    Dec 2008
    17,158
    Take the left one out mate. Mine looked fine till I took it out and the contacts were frazzled.
    S3 Build Thread
    Danman1's Avatar
    Thorough noob
    Sep 2011
    West Midlands
    338
    Alright cheers Westy, what would be my next step if the fuses are OK?
    Dan
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,846
    Quote Originally Posted by Danman1 View Post
    Dan
    Check if power is going to the circulating pump? If so, then pump is fubar'd!
    Danman1's Avatar
    Thorough noob
    Sep 2011
    West Midlands
    338
    Ok, so I volt metered the pump and fuses and no power was going to the pump so the fuses must be the issue, changed the fuses and bam, its back on. Quick pic of the fuse, looked fine....
    Cheers everyone for your help.
    Dan
    Westy's Avatar
    Dec 2008
    17,158
    Exactly the same as mine mate, hence why I told you to remove the fuse
    S3 Build Thread
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,640
    Nice, quick and easy fix there dude
    Danman1's Avatar
    Thorough noob
    Sep 2011
    West Midlands
    338
    Quote Originally Posted by Nilz View Post
    yeah, was expecting a ball ache of a job but turned out to be an easy fix, I was like it can't be this easy...
    Aug 2010
    1,540
    lol, 9 times out of 10 it isnt an easy fix....... that was your 1 easy fix......... sooooo theres 9 ball ache things to fix in your not too distant future.
    might be an idea to measure the resistance on the coolant pump. might be pulling too much current, hence the marks on the blades of the fuse? ive seen those fuse holders all melted round the fuses from components they supply being faulty.
  1. Quick question quick reply needed !!
    By Bradderz_1988 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd September 2011, 10:51
  2. QUICK QUESTION...QUICK ANSWER NEEDED!
    By vw754 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st April 2009, 16:33
  3. Quick question that needs a quick answer!
    By ScottSummerhayes in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2009, 16:12
  4. quick question?
    By BIG MUS in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2007, 20:24
  5. Quick Question?
    By Dean_20 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th March 2007, 16:17
