Sky InsuranceVolks Autos
    Jan 2012
    Australia
    47
    Front (rear) Control arm bushes TT / S3?
    Hi Guys,
    I got a full front end bush kit from powerflex for my S3, and am about to have the (front) control arms done. After some research - the consensus is not to use the powerflex bushes on the rear of the the control arm as they can pop out/cause harshness. It has been suggested to use TT oem bushes instead. - I'm about to order them from Audi and want to get the correct part... anybody know what PN I need?
    I'm planning to run with the powerflex bushes at the front of the control arms though...
    cheers,
    Justin
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,598
    Search is your friend..
    s3 front wishbone bushes
    <tuffty/>
    Mar 2012
    94
    On my TT i have powerflex front and R32 rear bushes, and I was advised that powerflex rear bushes were "agricultural" and can fail early.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,598
    If the R32 ones are non voided then they are the same as the TT ones.... there are 2 types typically... voided and non voided... there may be a third type as the LCR's had harder rubber bushes than std on some parts of the suspension (top mounts and front wishbone bushes spring to mind...)
    <tuffty/>
    May 2010
    Bedford
    2,877
    Only one part number listed for the R32 and thats the non-voided bush which is the same as the TT/S3 non-void bush. 8N0407181B £17.20 each plus vat.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
  1. New rear tie arm bushes
    By SiGainey in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th May 2011, 14:28
  2. Front suspension arm Bushes
    By TAC in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th March 2011, 23:41
  3. Changed front arm controller bushes but still squeaking
    By Neesh in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th June 2010, 16:05
  4. Front anti-roll bar & lower suspension arm bushes..
    By shah23 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd January 2009, 22:08
  5. Rear Arm Bushes...
    By FactionOne in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st February 2008, 18:40
