EM TuningJMB Retrofits
    James TQ's Avatar
    Apr 2012
    Essex
    548
    Question VAG COM codes... all five of them! help!?
    i am new to the vag com software and managed to figure it out, in the end i got 7 codes, the first two were only advisory the other five however... well
    17978
    17524
    18010
    17952
    17580
    16518
    i done some research on ross-tech but couldnt find some of the codes,
    id appreciate if anyone can diagnose these codes and the solutions to fix them, when the car is on idle it sits at 900rpm and raises and drops very slightly, also in 2nd and 3rd gear in the higher end of the revs it feels like its holding back power, could these codes have anything to do with this?
    i would appreciate any help in solving these matters, im sure i can rely on Tuffty, he seems to know everything about the 1.8t engines!! (:
    think the engine code is AJQ, Quattro 180bhp.
    cheers guys!!
    Jan 2012
    1,837
    17978/P1570/005488 - Ross-Tech Wiki
    17524/P1116/004374 - Ross-Tech Wiki
    18010/P1602/005634 - Ross-Tech Wiki
    First 3, couldnt find the other 3 .. And btw you have 6 fault codes listed there
    James TQ's Avatar
    Apr 2012
    Essex
    548
    thanks pal, ayye, they say the more the merrier... or not in OBD case haha, thanks
    James TQ's Avatar
    Apr 2012
    Essex
    548
    do you think the 17524, could this me deleted and ignored or may this be a cause of the car running a little rough?
    May 2012
    Quote Originally Posted by a6_chris View Post
    I've got the 17978 code in combo with 18263 and 16485 on my Audi A3 8P 2.0TDI 2003. Trouble is using that link to the Wiki it tells me this is an imobiliser related fault and that the eng start is blocked, but it's not!
    Have to dig a bit to find what the others mean!
  1. A3 vag codes - help please
    By jin2 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th November 2010, 14:08
  2. vag codes help
    By domg in forum VCDS (formerly VAG-COM) forum
    Last Post: 30th March 2010, 12:52
  3. VAG COM codes
    By hammondr in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th July 2009, 10:09
  4. VAG com codes
    By K3nnFFu in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th March 2009, 11:46
  5. Help !! vag com codes
    By Essflee in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st April 2008, 19:07
