Volks AutosMonster Motorsport
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    Question Audi S3 power steering fluid leak HELP
    I noticed a leak of power steering fluid under my car a few days after I came back to the car after a few hours.
    The plastic engine under tray has a small hole in it so it has dripped through there. It hasn't leaked anymore which is unusual. No warning lights, power steering works fine, no problems what so ever.
    I have checked the power steering fluid level, level is fine. The fluid is a dirty brown colour instead of the usual dark red.
    Are there any rubber or metal pipes that are prone to failing or leaking with this system?
    2002 225 S3, metallic black, REVO, 18" RSTT alloys, goodyear Eagle F1s, silver leather heated seats, tinted windows, H&R spacers, black diamond grooved discs & Ferrodo DS2500 pads, BOSE system, xenons, forge DV, samco TIP & upper boost hoses.
    Chugger
    North Devon
    2,716
    There is a metal power steering cooling pipe which rust's out. It's at the front on the bottom as is attached to the metal pipes that links the coolers, that's the usual culprit
    57 A3 2.0 TDI Sportback (140)
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Power steering failure
    Sounds like the issue i had
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
  1. Power Steering FLuid - Leak?
    By S4 Muzza in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th October 2011, 06:52
  2. Power steering fluid leak - anyone used Lucas power steering fluid leak stop?
    By DodgeT in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th October 2011, 19:27
  3. power steering fluid
    By vw754 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th January 2009, 21:11
  4. Power steering fluid leak
    By low610 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th November 2006, 20:38
  5. Power Steering Fluid Leak
    By imported_kbininger in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd August 2005, 19:36
