Volks AutosSky Insurance
Results 1 to 7 of 7
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    286
    Can someone give this engine picture the once over...
    Hi guys, just taken the car out for a test and it is flat as a pancake... im thinking collapsing hose under boost but before i take of this TIP and put it back to standard.. can anyone see anything plugged in wrong / wrong way around that could be my issue?
    symptoms are 1st gear picks up great for ..... 4 seconds then everything goes flat.. no power
    ive changed the spring in the 008 to a yellow.. no diff... back to std DV.. no difference
    air filter taken off so tip has no kink... no difference
    help me please
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    N75 plumbed in wrong.... the one going into the TIP is where boost should go... the longest outlet on the N75 goes into the TIP
    <tuffty/>
    vrbob's Avatar
    Jun 2007
    Southampton
    2,285
    also the pipe to your hockey puck from the TIP is kinked massively too in the pic
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    286
    Tuffty you are completely right! What a muppet I am. I had so much off the car recently i slipped up on this!
    thanks mate.. second pair of eyes always helps!
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    286
    Quote Originally Posted by vrbob View Post
    It is indeed Rob, im going to have to get an aftermarket hose for that... the original is like melted goo.. so crap its unreal!!
    will that cause any massive issues in the running of the engine of left like that till the weekend? on to etka as I type!
    Schlaag's Avatar
    Bwah
    Jul 2007
    Kent
    286
    Sorted. Long n75 pipe to TIP, left side to actuator and bottom to charge pipe
    vrbob's Avatar
    Jun 2007
    Southampton
    2,285
    Yeah i had to raid my dads assorted odds and ends to find some pipe to repalce the same hose as mine had about as much strength as a wet paper bag!
  1. I give up
    By S4_dan in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th October 2011, 13:54
  2. S3 Engine Picture Request
    By darreng1983 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th October 2010, 19:36
  3. For the 1.8t AGU engine, I need a picture of...
    By luckymacy in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th December 2009, 04:57
  4. I give up...!
    By Clach in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th July 2008, 23:52
  5. I give you . .
    By Olly_K in forum General Chat
    Last Post: 11th June 2006, 10:29
