EM TuningBadger5
Results 1 to 11 of 11
    Dec 2011
    Hockley Essex
    309
    what springs to fit on the back to get it lower with ap coilovers?
    Fitted my ap coilovers this weekend and i want the back to go lower. Has anyone fitted different springs to archive this?
    Any help would be great .
    Many thanks
    knoxie's Avatar
    K4OXE
    Aug 2011
    harlow, essex
    619
    hi john, sorry that its not answering your question but could you post a pic of your car with the coilovers on? did you have to change anything else to get the camber correct?
    Dec 2011
    Hockley Essex
    309
    No worries .This is with ap coilovers with the rear adjusters out and only the spring in and it still not low enough. You have to fit adjustable tie arms when lowering over 25mm i believe. hope this helps .
    knoxie's Avatar
    K4OXE
    Aug 2011
    harlow, essex
    619
    thanks mate, those wheels look awsome!!!
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    I've got AP's and mine was that height at the back before I removed the adjusters.
    Think the only way to get it even lower is to get different springs.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    take the anodised blue adjuster out. that will lower it another 10mm-ish
    Dec 2011
    Hockley Essex
    309
    Already taken out the blue piece only running the black bit . Been doing some searching and alot of people have brought silverline springs to get it lower so iv emailed FK and hopefully get a reply tomo . There only meant to be £80 too so not to bad .
    Dec 2011
    Hockley Essex
    309
    Right iv ordered two FK silverline rear springs so hopefully they will sort out the problem .
    If anyone else would like to order some the part number is:
    FK88HA/4
    24€ each spring and 14,49€ p+p
    Which worked out £52 pounds all in. Just phone 004971913275180.
    Jun 2012
    Quote Originally Posted by S3 JOHN View Post
    FK88HA/4
    Hello mate did the springs work cos I'm having trouble with my ap coilovers?
    BENJAMIN's Avatar
    Mar 2011
    472
    Pm 'supreme' on here. He has ap's and we sent his rear springs away to be shortened by 15mm. The car runs only these springs with no adjusters, it's very low.
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Quote Originally Posted by BENJAMIN View Post
    Shortened how?
    PS3: Broady_11
  1. pi lower springs 45mm
    By tdi-man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th October 2011, 14:05
  2. lower springs
    By vr6gordy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th August 2011, 20:16
  3. what springs will fit an audi a3 in the back
    By 20v-turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2011, 08:38
  4. what springs to lower my 06 plate A4 ?
    By carsevolution in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 29th October 2010, 05:32
  5. 97 1.8TQ Which springs to lower with???
    By jetspeed in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th May 2004, 22:17
