Sky InsuranceVolks Autos
Results 1 to 18 of 18
    Apr 2012
    93
    Unhappy help please, advice needed.
    hi all, while trying to bleed my brakes i snapped 1 of the small bleed nipples off on the master clinder, its not leaking just snaped off, ive still got air in the system, the question is, can i get it pluged in to vagcom and bleed the brakes that way without changing the broken bleed nipple??, thanks in advance. martin
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    How on earth is VAGCOM going to bleed a hydraulic system? VAGCOM is a software sytem that interacts with your cars ECU so iunfortunately its not going to be of any use whatsoever in bleeding your brakes. Youll either need a new master cylinder with new nipple or if you can remove the remains of the old nipple and fit new.
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    Apr 2012
    93
    u need vag com to get the air out the m/c ,
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    Quote Originally Posted by HOTTIGGER View Post
    No... you don't... you need a bleed nipple to get air out the master cylinder... VCDS can be used to help bleed the ABS pump if it still has air in (which is very rare)
    There are 2 bleed nipples on the MC... have you broken both or just the one?
    <tuffty/>
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    4,003
    I had one snapped off, because a garage did it up too tight previously and it would bleed jst fine. Just keep an eye out for leaks.
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Honestly, I dont know how you can get air in the master cylinder.. Always assumed the two nips on the m/c were to let the old fluid out when being really anal changing the brake fluid.
    Dane's Avatar
    Cheltenham
    4,003
    Every brake fluid change done on my s3 needed the mc bleeding to bring back the pedal. Some don't need it doing some do...
    Apr 2012
    93
    Quote Originally Posted by Dane View Post
    thanks m8 nice 1, some people on ere,,, two weeks people told me i need it bleeding on vagcom, then when i ask the try make u look a fool..
    Apr 2012
    93
    Quote Originally Posted by MrCSW View Post
    !Honestly, I dont know how you can get air in the master cylinder.. !!!!!!! it was already in there !! and i dont think its bing anal bleeding the 2 nipples on the master cyilnder, as for 2 weeks now everybody on hear has told me to bleed the m/c and the clutch when bleeding the brakes!!!!!!!!
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    You don't need to bleed the clutch.
    Audi A3 1.8t AUM
    Forge 007p, Pipercross Panel Filter, Eibach Prokit 35mm drop, EBC Green Stuff Pads
    Groved Disks, HEL Braided Brake Lines with Dot 5.1 fluid.
    Creation Motorsport Silicone TIP,
    N75 hoses, DV Hose & 10mm Rear Wheel Spacers
    Powerflex Rear Beam Bushes & Diesel Dog Bone Bush
    8k HID Kit, 8k LED Side Lights, 8k Number Plate LED
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    If changing the fluid its worth bleeding the clutch as it uses the same fluid store as the brakes... the fluid will be in the same sort of sate as the rest... whilst arguably not as critical as the brakes its something that if overlooked for some time could contminate the nice new fluid you have just changed or lead to slave/master cylinder issues later on..
    Seems a false economy to me not too bleed through the clutch when doing a full fluid change to me...
    <tuffty/>
    Apr 2012
    93
    i thought that myself m8, but according to people on hear u need to bleed 7 nipples, 4 on the wheels 1 on the clutch 2 on the m/c...
    anyway ive broke 1 on the m/c,, can i still bleed them without changing the broken nipple.
    Quote Originally Posted by Metro View Post
    Apr 2012
    93
    is there anyway of bleeding them without changing the broken nipple?? thanks
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    If you can undo the nipple that isn't broken then you have a chance of getting the pedal a bit former but without a nipple to let the air out then there is no way to get the air out of that part of the MC... as I have told you via pm, you will need to remove the MC to stand a chance of removing whats left of the broken bleed nipple (if possible at all) else its a new MC from GSF/ECP or a dealer...
    <tuffty/>
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Sorry, I didnt mean to hit a nerve or my repsonse to sound blunt.
    The only reason the bleed nipples are on the m/c is to relieve air from the primary and secondary piston assembilies.
    There should never be a reason for air to get into these chambers.. providing the fluid level has not got too low. (or fitting a new empty m/c)
    For a fluid change if done "correctly" you shouldnt need to bleed the m/c at all.. or the abs pump.
    Aug 2012
    Have you seen the new Bleed Nipple replacement kit, developed by Fraser Brown, you can see him in action on u tube, what a great time saving invention, I bought one online at Rapid Tools Direct.
    Aug 2012
    Nipple Therapy - Replacement Bleed Nipple Kit, from Rapid Tools Directbleed-nipple-kit.jpg
    Aug 2012
    Have you seen the Nipple Therapy kit by Frazer Brown, you can see it working on u tube, you can repair a broken bleed nipple in under 10 mins. I bought one online at Rapid Tools Direct it is great I will put the page link here for you it's only about £75 for the kit.
  1. Advice needed please!!!!!
    By Reiss87 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th March 2012, 18:55
  2. Advice needed please
    By markie A3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th April 2011, 12:25
  3. Advice Needed
    By LucasS3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th April 2011, 21:42
  4. Advice needed please
    By Mindrunner in forum VCDS (formerly VAG-COM) forum
    Last Post: 27th March 2009, 12:43
  5. advice needed
    By Toots in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2006, 14:29
