Volks AutosJMB Retrofits
    S3 Tim's Avatar
    BAM!
    Apr 2011
    Herefordshire
    32
    Changing sidelight bulbs, remove washer fluid tank?
    I recently bought some LED sidelights and was going to put them in the other day, however there is no room to get the rear cover off the driver side headlights. It looks like on the passenger side it will be fine when the battery is out, but can you do the driver side without taking the washer fluid tank out or do you have to do that.
    Is it easy if so and do you have to empty it or not?
    I had a look in the workshop manual but couldn't see anything about it.
    Thanks,
    Tim
    wallace78's Avatar
    Mar 2012
    belfast
    146
    Just take the lights out four scews just that's how I did mine 5 min job
    knoxie's Avatar
    K4OXE
    Aug 2011
    harlow, essex
    619
    i can get mine off no problem, i then just gently pull the wires for the side lights and bingo :-)
    S3 Tim's Avatar
    BAM!
    Apr 2011
    Herefordshire
    32
    Quote Originally Posted by wallace78 View Post
    They are the self levelling xenons, will this upset them at all or is it fine?
    Quote Originally Posted by knoxie View Post
    I popped the back off and couldn't even get the back out, it's jammed in so tight! There is the washer bottle and then some cables wedged in between, I tried to slide it up and out for about 5 mins but no joy, could squeeze my fingers in and touch the wires but didn't want to pull anything out as might not be able to get it in again!
    Oct 2010
    45
    done mine, it is a little tight but I removed nothing just a gentle pull on the wires easy, but I did brake my nail changi
  1. Black box between expansion tank and washer tank
    By Goubo1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th January 2012, 21:29
  2. A6 (C5) changing sidelight bulbs
    By HerefordQuattro in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 8th April 2010, 20:01
  3. Changing sidelight bulbs on a 2000 S3.
    By lloydsta101 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd November 2009, 22:11
  4. Sidelight bulbs in S3
    By banoffee in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th September 2009, 15:19
  5. sidelight bulbs
    By Khufu in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th April 2004, 12:49
