Badger5Chris Nott
    Oct 2009
    clutch master cylinder rod bent
    hi peeps, i had a mechanic look at my car the other day because my clutch pedal went to the floor and didnt come back up, as it happens it was only the pedal that needed doing, while i was putting the new pedal in, i noticed the rod in the master cylinder thant connects to the pedal has a bend in it, was wondering if this is sapposed to be bent or is it the mechanic that has bent it when trying to get the old pedal out?
    cheers
    Daz
    beachbuggy's Avatar
    Surrey
    1,741
    It's not meant to be bent ie straight but I know for a fact on my brothers a3 it's slightly bent and we only found that out after his clutch pedal snapped, now whether it was like this before or as a result of the pedal snapping I have no idea but we left it as is and it's never been a problem since. Try it, worst case you have to remove it, straighten or replace. I have a feeling they bend with the sudden shock when the pedal snaps.
    Oct 2009
    yeah i didnt think it should be bent, thanks for your reply, il keep an eye on it, seems strong even though its bent,
    thanks again pal
    Aug 2010
    1,540
    they tend to bend when the pedal breaks. they quite easy to bend put a ring spanner on it a tweak it straightish.
    Oct 2009
    ok mate will give it a go tommorow when i finish putting it on, cheers
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    They are supposed to be straight.when my pedal snapped,mine was straight. If its operating correctly then leave it be
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
  1. Clutch slave cylinder or master cylinder ?
    By ColinS in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th February 2013, 21:29
  2. clutch master cylinder
    By sydneyc in forum The Welcome Section
    Last Post: 24th March 2009, 22:17
  3. Clutch Master Cylinder
    By metricspaces in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th January 2009, 10:43
  4. Clutch master cylinder...
    By tommo-turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th September 2006, 19:35
  5. Clutch Master cylinder issues.....
    By nlw73 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2005, 08:59
