- Joined
- Jul 11, 2011
- Messages
- 1,860
- Reaction score
- 443
- Points
- 83
Trying to get my S3 back on the road and have a MOT on Tuesday. At some point in the cars life i believe the airbag has gone off and the previous owner has just stuffed it back in and put a dab of glue on the flap with the airbag behind.
after a bit of research i found this: VWVortex.com - Airbag light...how did you trick your ECU?
so i purchased a 2.7 ohm resistor, just plugged it into the airbag connector, reset the ECU and it doesn't seem to have done the job
Does anyone know what the resistance of the airbag in the seat should be and or where i might be going wrong? I'm assuming that the brown wire is an earth, do i need to do anything with this?
Any help would be appreciated as i NEED to get her back on the road so I can start earning some money again!
thanks
thanks
