EM TuningBadger5
    Dec 2011
    125
    Slight throttle body issue
    i have an agu and there seems to be something up with the spring in the throttle body, i accidently put my foot on the accelerator when the engine was off and when i took my foot off the pedal was still down to the floor! iv noticed that when i put my foot to the floor when im driving and let off the car is still revving for almost half a second afterwords, only other thing iv noticed is that the accelerator cable is on the last notch on the plastic grooves on the cable and te is a fair bit of slack before the pedel is touched, dont understand why the metal spring in the throttle body is so tight to stick when it fully open, any ideas anyone? also im sure there is suppose to be something that holds the nipple on the end of the throttle cable in place as on mine someone has made up a bit of wire going through the hole on the plastic C shaped piece, if that makes sense
    Dec 2011
    125
    anyone?
  1. New to the site, have a slight issue!
    By Tom-E in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th January 2012, 09:31
  2. slight judder on throttle
    By jasona3turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th October 2011, 13:13
  3. slight issue
    By jonnyf in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th September 2011, 18:26
  4. Slight Fueling Related Issue Maybe?
    By Wizza in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd August 2011, 00:52
  5. Throttle Body issue
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th June 2008, 12:13
