JMB RetrofitsAH Fabrications
    Mar 2012
    Bradford
    56
    Would leaking rear shock cause wheel camber?
    Hi guys,fitted some 15mm hubcentric spacers on my s3 8l the other day,and noticed my near side rear wheel was cambered inwards,and possibly a bit of toe in too.it may have been like that before the spacers but not noticed it maybe because the wheels sat inside the arch anyway. The car has standard suspension all round(5 pink dots on the rear springs)
    ive just had the wheel off to look for anything obvious but the only thing I see is the rear near side shock looking abit sorry for itself,
    Anybody think that this could be the issue with the camber?
    Cheers guys
    Rich
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    No. shock won't bother it, they just provide damping, not support.
    Worn bushes, springs, snapped springs, bent tie bars, could all be possible causes if excessive camber.
    Btw, there is supposed to be around 1 degree of rear camber as standard.
    Mar 2012
    Bradford
    56
    Hi mate yes the springs were one of the first things I checked,there's surprisingly in good condition,must of been replaced not long ago,yea I understand about a little bit of camber but this is just on the passenger side,the drivers side looks as it should do.
    Which bushes are most likely to need doing?
    Rich
    Mar 2012
    Bradford
    56
    Anybody know? I'm going to goodwood festival of speed in a couple months and it's a long drive from where I am,just want the car to be spot on before I go.
    Thanks guys
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Quote Originally Posted by S3 rpm View Post
    Rich
    the inner tie arm bushes (x4 each side)
    and the rear trailing arm bush (x1 each side)
    the car will likely need alignment after these tho
    Mar 2012
    Bradford
    56
    Cheers man,il get on eBay get some ordered
    Rich
  1. Rear Camber, rear twitch, Standard car???
    By Craig_T in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th January 2012, 00:05
  2. 4 Wheel Alignment + Camber
    By mat_vw in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th July 2010, 16:55
  3. Wheel Alignment for Rear Camber
    By jomnhta in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th March 2008, 20:44
  4. rear camber with damaged shock?
    By aidank1981 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th March 2007, 08:30
  5. Rear Wash Wipe, Water leaking from wheel arch!
    By Gajjii in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th July 2006, 01:13
