AH FabricationsEM Tuning
Thread: o2 sensor test
    actualeddie's Avatar
    Feb 2012
    Waltham Abbey, Essex
    211
    o2 sensor test
    Managed to get to my o2 sensor after an error code indicating that it may not be working. Is there a way to test.the sensor before i spend out money on a new one?
    Vwdan80's Avatar
    Nov 2011
    South east
    100
    It can be tested using vcds, think there is a cat and sensor testing mode on one of the measuring blocks
    2002 s3 silver, BAM, lcr Brembos ds2500 pads, Braided hoses, forge 008 dv, stack boost gauge, power flex dog bone bush/wishbone bushes, forge boost hoses, B5 tip, B5 remap, toyo fmic
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    What was the error code again? generally speaking they are not in a position where wiring is an issue... yours is an APY S3 isn't it? thats a narrow band lambda, not mega bucks tbh...
    <tuffty/>
    Feb 2012
    211
    Ill dig the error code up later, about to watch american reunion . Noticed the garage over oiled my car, which causes the cat problems right? Could that have something to do with it?
  1. Replies: 2
    Last Post: 5th April 2012, 23:01
  2. A3 sport 130 N75 valve & Thrust sensor(boost pressure sensor) brand new genuine
    By BuckleyTDI in forum For Sale/Wanted - Audi Parts
    Last Post: 5th March 2012, 13:11
  3. Clutch position sensor and brake pedal sensor??
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th October 2011, 15:33
  4. Replies: 2
    Last Post: 25th June 2011, 12:13
  5. Coolent warning light and sensor, easy to replace sensor
    By MingeBlue in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st January 2011, 14:21
