Badger5EM Tuning
Results 1 to 13 of 13
Thread: Clutch!
    Jul 2011
    15
    Clutch!
    I guys i have a 98 a3 1.8 turbo 150 bhp model, quite new to this so here goes, today my clutch started slipping, not bad in first and second but from 3r
    d gear up from about 3k rpm is just revs and nothing else, will i have to replace just the clutch pr more? And i am thinking of a remap soon as i already have a few mods, woyld it be a waste of time putting in a standard clutch, would i need an aftermarket clutch to cope with the remapped extra power? Any help wpuld be fantastic.
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Prawn is your man who has a lot if experience with clutches on these but if I remember correctly the vr6 single mass flywheel and clutch is the one to go for but I'm sure someone will tell you the specifics
    If not have a search as it's been covered many of times but you need one for the a3 as the s3 is different
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    You should get a vr6 clutch and a g60 flywheel, all for under 200 quid. It's will cope with more than the power you want and is reliable.go for it before you clutc goes lol
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    Jul 2011
    15
    no problem thanks for the advice
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,388
    Hello matey, got your PM, thought I'd reply in here so it comes up for anyone searching in future.
    As said above, what you need is an ABF/G60 flywheel (they're the same), and a vr6 clutch kit.
    The flywheel is most easily found from an ABF engine, which was fitted to the mk3 golf 2.0 16v, so common as muck, it's also on the G60 engines, but these arn't so common.
    If you're anywhere near Hampshire, I've got an ABF flywheel sat in the garage if you wanted to get one second hand.
    As for the clutch, you need a vr6 3 piece clutch kit, for a 2.8 AAA engine, consisting of pressure plate, fritcion plate, and release bearing. These are about £150 from VW, or £90 from GSF, I ran GSF LUK clutches for years without any problems.
    You'll also need all the 6 flywheel - crank bolts from an ABF engine, you can't reuse yours, they are too long. also get the small bolts that hold the pressure plate to the flywheel. All the bolts in total are about £15 from VW
    The flywheel is lighter, the clutch is stronger (it'll take 300lbft), and the pedal feel is also much improved! it's win win win, all for not a lot of money
    Jul 2011
    15
    Spot on matey thanks allot ! :D
    Jul 2011
    peterborough
    33
    Does anyone know what the part number would be for both of these?
    Feb 2011
    Somerset
    241
    I baught a complete kit from tecniclutch through ebay, I only paid £130 for the lot including the bolts delivered, all fitted perfectly, its been on the car for about 4K now and no probs at all, nice and light on the left leg too.
    Customboy's Avatar
    Jan 2012
    SE London
    836
    I'm glad i got my kit for £60!!
    p
    THE BLUE BEAST, TAKEN FROM ME, GONE BUT NOT FORGOTTEN
    RTECH STAGE 2 REMAP NOW RUNNING 223 BHP AND 253 FTLB OF TORQUE,
    SUBARU IMPREZA WRX ESTATE SOON TO BE RUNNING 340 BHP
    ANTI LAG/LAUNCH CONTROL/MAF LESS/ LOVE IT !!
    Feb 2011
    Somerset
    241
    Quote Originally Posted by Customboy View Post
    Wow, result :-)
    Jun 2010
    Milk n Beans (Milton Keynes)
    109
    Great reply Prawn, that's saved me a headache.
    My S3 is currently on 126k miles, X-reg and never had the clutch or flywheel changed (original OEM).
    It wasn't until another S3 owner (51 plate, 40k miles) said his dual mass flywheel had just gone and fckd his car up costing him a fair bit for repair.
    I didn't realise the clutch and flywheel on 8L S3 was so poor?
    So at 126k miles on original clutch and flywheel I should seriously be considering a change?
    Jun 2012
    289
    Evening all! 1st post - BOOM
    Prawn, will this set up work for the AMK lump?
    Cheers fella
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,613
    Clutch plate is larger on the S3... 240mm vs 228mm
    <tuffty/>
  1. Clutch/Clutch pedal problems
    By Banjonez in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th June 2010, 13:32
  2. CLUTCH
    By CMD in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th June 2010, 21:50
  3. New Clutch
    By aliperry in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th November 2008, 17:56
  4. clutch help
    By racerkid626 in forum Tuning
    Last Post: 24th August 2007, 04:36
  5. Clutch
    By Barclaygreyhound in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st October 2005, 14:12
