EM TuningMonster Motorsport
Results 1 to 11 of 11
    Mougge's Avatar
    Feb 2012
    Northern Sweden
    38
    upper boost hoses
    I wondering if anyone know the diameter of the hose that goes from hardpipe to intercooler ?
    Specially the end to intercooler ?
    Please help!
    Dahlbäck Racing Map, Head and Dump.
    Ferrita stainless steel exhaust.
    Sachs organic race clutch and pressure plate.
    Fidanza monolithic aluminum flywheel.
    Toyosport Intercooler.
    Upgraded and checked turbo.
    Checked gearbox.
    Shortshift Forward / Backward, Left / Right
    Bilstein B8 Sprint around
    H & R 25mm springs all around
    Neuspeed Front anti roll bar 22mm
    Neuspeed rear anti roll bar 19mm
    Forge Tie bar
    Haldex Performance Generation 1
    etc...
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    On what car?
    <tuffty/>
    Mougge's Avatar
    Feb 2012
    Northern Sweden
    38
    Audi S3 year 2000 8L
    I have fitted wellycooler so I have 2.5 inch from intercooler . But need to replace orginal hose from hardpipe
    Checked gearbox.
    Forge Tie bar
    etc...
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    S3 charge pipes are 60mm...
    <tuffty/>
    Mougge's Avatar
    Feb 2012
    Northern Sweden
    38
    Will it fit my 2.5 inch joiner ?
    Checked gearbox.
    Forge Tie bar
    etc...
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    2.5" is 63mm (give or take) so could be squeezed over... I have used 60mm silicon bellows joiners on 63mm pipe before... to be honest it depends on the the hose... I have seen 60mm hoses that are either a loose fit of a tight fit on 60mm alloy pipes...
    Are you looking to replace the hose coming from the grey hard pipe up top that goes between the washer bottle and the headlight? why not just buy an aftermarket kit like the ones Forge sell?
    <tuffty/>
    Mougge's Avatar
    Feb 2012
    Northern Sweden
    38
    Like this one ?
    Forge Motorsport | Alloy Fabrication
    or this ?
    RAMAIR SFS Silicone Hose Kit S3 Upper Boost Hoses 1.8T | eBay
    Thats why I am wondering , I asked about those hoses and got the answer it replace the original hose. That means its 60mm on the end to the intercooler ?
    Checked gearbox.
    Forge Tie bar
    etc...
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Thats the fellas
    <tuffty/>
    Mougge's Avatar
    Feb 2012
    Northern Sweden
    38
    Thinking of RAMAIR SFS Silicone Hose Kit S3 Upper Boost Hoses 1.8T | eBay
    Much cheaper
    But then I just have to hope I can squeeze that 60mm hose over my 63mm joiner ?
    Checked gearbox.
    Forge Tie bar
    etc...
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Should be ok mate....
    <tuffty/>
    Mougge's Avatar
    Feb 2012
    Northern Sweden
    38
    I trust you tuffty !
    Will also order some real clamps and a Bager 5 tip
    Checked gearbox.
    Forge Tie bar
    etc...
  1. 17963/P1555 - Boost Pressure Control: Upper Limit Exceeded :(
    By Dubstep in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd November 2011, 21:39
  2. Slight Upper Boost Hose issue!!!
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th February 2010, 21:36
  3. Boost hoses.....
    By markyp2002 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th March 2009, 10:14
  4. Samco Upper Boost Hose - Tight Fit?
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th May 2008, 15:19
  5. S3 Metal Boost Hoses
    By DPM in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th October 2007, 10:18
