Volks AutosEM Tuning
    Nov 2011
    Air con not very cold and blows black foam from vents
    Gday guys,
    I have a problem with my air con system, its not overly cold. I had it re-gassed recently which helped a little but not much.
    When im stationary the air blows cool, but when i drive at speed it blows warm. It also seems to be cooler at lower fan settings. Im also getting heaps of little pieces of black foam coming out of the vents..
    Any suggestions?
    Cheers!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    I think you have answered the question yourself mate... the foam is most likely the seals used on the flaps to control where the stream of air is coming from and I suspect the issue you have is that warm air is leaking past the flaps and mixing with the cold...
    <tuffty/>
    Nov 2011
    Thanks for the reply.
    Whats the part called where the mixing flaps are? Do you know whats involved in fixing it?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    I would imagine it involves removing the dash to get to the heater unit as all the flaps etc are behind there... not had one out of an A3 so not sure where they are exactly or whats involved but I have removed the heater unit from my A4 to change the matrix and that was a ball ache...
    Have a look in the maintenance manuals in the stickies as they may have details in there... failing that then maybe a Haynes manual might help...
    <tuffty/>
  1. first warm day.....no cold air from vents :( .....where do i start?
    By chazza55 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th March 2012, 15:27
  2. Air con not cold.
    By mattyboyc in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th April 2010, 19:54
  3. air con is just not cold enough
    By khalil in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th May 2008, 19:54
  4. air con dont like the cold
    By jeffers999 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th January 2008, 22:51
  5. Not That Cold Air Con !
    By imported_Pmcgeorge in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th August 2004, 16:47
