Monster MotorsportChris Nott
Results 1 to 25 of 25
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,236
    Question Lcr Top Mounts.... Look to have failed already
    As title says, looks like my lcr top mounts have failed already, they've only been fitted 10 months and around 6-8k miles and they look to be shot.
    Went clunk hunting tonight, jacked the car up and took the passenger side wheel off, every suspension component was sold except for around the top mount area.
    Their was paly in that area and a low pitched version of the knocking im getting.
    So has anyone else had this? Going to get a garage to double check but if its right im looking at fitting these:
    Alloy Suspension Turret Top Mount Vag Audi TT S3 Seat Leon Golf Mk4 Skoda Octavi | eBay
    Will they be up to withstanding harsh roads and collies?
    I believe my current setup may have helped kill them quicker, im running kw v2 collies and they were set pretty hard and the roads around me are ****e.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Mine have been on a while with no issues mate...
    <tuffty/>
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,236
    I know thats thing, the top mount and turret were loose mate, so i tightened them up last week but the 11mm nut on the kw damper has turned to mush so cant grip it anymore, going to get a garage to air gun the 21mm nuts and see if that helps, how do you tighten the nuts up mate?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    I use an impact gun...
    <tuffty/>
    Feb 2008
    2,818
    Worrying as I was looking into these as advised by Gops too. How much of a difference over standard are they?
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Much harder than std.. tbh I cannot see how there can be an issue as these are OEM mounts... I have had no issues whatsoever with mine on my B8's... this could just be an isolated incident... these are no worse than the std ones tbh...
    <tuffty/>
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,236
    Thought thats the best way, is it normal for the top mount turrets to have movement? i.e. if i use a 21mm drop spanner i can move them left or right?
    Chugger
    North Devon
    2,716
    Hmmm same thing happened to me, top mount and bearing were clunking badly after hitting a pothole, found it was because I had fitted the top mount upside down so the bearing wasn't correctly supported - the bearing was smashed to bits!!!
    57 A3 2.0 TDI Sportback (140)
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,236
    As tufty said this may just be a isolated incident, im going to get them impact gunned and see how they are, if that doesnt work then i know their 100% shot and ill be getting the rose jointed ones.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,236
    Double checked mate, their are definitely fitted the right way .
    Chugger
    North Devon
    2,716
    They will move left to right when jacked up :/ if there is excessive movement when there's load on it or if one sits higher than other, there buggered. I presume you replaced bearing at the same time
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    I still can't see how it would be the mount tbh... they do compress over time but I would imagine (depending on how low you have the coil overs) they could get wobbly on them... on a set of normal struts I am struggling to see how they could go unless the bearings have gone...
    <tuffty/>
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,236
    Tufty did you get a knocking when the bearing went? The car is quite low, id say theirs less than a inch gap between the wheel and wing.
    Sportstractor: yes their is still movement on the passenger even when not jacked up and all 4 wheels are on the floor and yeah i replaced both front struts with new oem bearings.
    Chugger
    North Devon
    2,716
    Mine made a horrible clunking when mine went, mostly when going over bumps and turning, even minuet ones
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,236
    What when your mounts went or the bearings? Mine is knocking even over slight differences in tarmac.
    Chugger
    North Devon
    2,716
    Bearing went, I think it's wise to change both if doing the job, lemforder ones are dead cheap and the same thing
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,236
    If the bearings have gone then ill be changing the whole lot, less than 8 months and £15 worth of bearings shot, its going to start adding up lol.
    Well ill get the top mounts impact tightened on saturday, if the knockings still their then ill get them took apart and see whats what but im not holding my breath lol.
    London
    160
    If I was you I would not buy them alloy suspension top
    Mounts,I fitted them and was not impressed
    Alot of road noise and loads of noise when turning
    The wheels lock to lock
    Just think about it
    Two pieces of aluminium top and bottom with two silly
    "o" rings and in the middle is your cars shock hole
    Trust me eats the o ring up in no time
    Total crap
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,236
    Oh right, so did you have the above ones then mate? The last thing i want is that kind of hassle, i cant do with the knocking ive got now, so if a get a constant similar noise from the above even when fitted right, that's proper p*** me off.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,790
    Stacey has rose jointed top mounts. They're used on plenty of cars too. If you go with a good rose joint they should be fine...
    If it helps, I have a similar knocking over small bumps sometimes but I know that my wishbone bushes need doing. My top mounts and bearings are new and tight as a camels arse in a dust storm.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,236
    Ill drop him a pm.
    Aint them mate, their all brand new and less than 6 month old and no movement at all in th.
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,641
    Dani did you ever sort this, I'm getting this noise and I'm sure it's the top mounts! Around sheff this weekend if your free, was wondering if you could help me diagnose this bluddy noise to weather it actually is the top mounts!
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,236
    I wish it was mate, it turned out to be the bloody coilover, £300 later and the noise was fixed.
    Ill happily meet up mate but can today, if it was yesterday id have been free lol. Drop me a pm with your number and well sort out meeting, you up next weekend (friday onwards im free).
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,613
    Quote Originally Posted by Gops View Post
    Surprised you never swopped to new ones whilst the springs was changed Gops, parts are like £25?
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,641
    PM'd dani!
    And Jo, when i got the car from you, i changed them then. I didnt think they needed doing again but what im gonna do is when i get a spare nice day, im gonna just change them again and see if that cures it. If not then its gonna need the dampers coming out to check them.
  1. Anyone who has fitted LCR top mounts?????
    By IOM-S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st March 2011, 09:36
  2. Following on from the LCR Top Mount info... ( LCR Wishbone Bushes )
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2011, 14:00
  3. LCR top mounts, Ball joints and Drop links.
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th February 2011, 20:08
  4. Top Mounts
    Last Post: 10th February 2011, 17:26
  5. Which top mounts
    By S3PEG in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th March 2010, 13:15
