Volks AutosMonster Motorsport
    Sep 2010
    498
    Don't think I have fitted the dash back correctly
    After having an issue with my brake light switch, I fitted the dash piece back together but don't think it's quite together properly. The bolts all lined up fine but it just didn't want to clip in properly. This is how it looks:
    Also, whilst I was under there, it looks like theres a fuse missing. Am I right? Mine is a 1.9tdi Quattro.
    Any help would be immensely helpful!
    damo.h's Avatar
    DVLA Say it's Black
    NW
    3,608
    Na that's not sitting right mate. I'd backtrack and clip it in correctly. Or is that stating the obvious lol.
    Mass for the fuse I'd refer to your manual and see why the fuse is for and see if it's needed. hopefully it's not been pulled on purpose.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    There is a metal clip either side of the column that the lower part of the dash clips into... its advisable to locate the plastic part of the dash that goes into this clip properly before giving it a short sharp tap with your hand to drive it home... careless bashing will result in the metal clip deforming and/or the plastic bit breaking off...
    By fuse I assume you mean relay? Probably for an option you don't have so nowt to worry about...
    <tuffty/>
    actualeddie's Avatar
    Feb 2012
    Waltham Abbey, Essex
    211
    i hate those metal clips, all over the car and always bend
    Sep 2010
    498
    I took the dash off because the brake light switch wasn't working properly. However, I took it off, popped it back on and it was fine. Anyone else had this problem? Do you think its best to buy a new one?
  1. VHC - N/S/F bottom arm bush not fitted correctly
    By Dan-Jnr in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th August 2011, 09:10
  2. LED tail lights fitted, dash light on
    By sam4191 in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st August 2009, 17:57
  3. Coilovers fitted -knocking from back
    By g60leigh in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th March 2008, 17:47
  4. can someone confirm i have fitted my sprintboster correctly??
    By Craigybaby37_A3quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th November 2007, 23:49
  5. New back shocks fitted
    By Amchlolor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th June 2006, 13:15
